Palmers 940 D24tic
Post 590577 by Palmer on 2013-03-31 00:06:26
I'm going to use this space to document various happenings / doings to my newly acquired 940 diesel. Its a 2.4L straight six turbo diesel intercooler (D24tic)
It started out with me browsing ebay looking at a few motors, when I came across this. I messaged the buy with a cash offer and he accepted. So I filled my mates fuel tank the next morning and set off to Leeds, West Yorkshire.
Few piccies from the ebay add:
Lovely condition seats
Original fire extinguisher!
Arrived in Leeds, looked over the car and accepted the deal, and began the journey home! After stopping off for a much needed Maccies of course! I was driving home mainly by myself as my mate took the wrong turning and nearly ended up in Manchester! Whilst I was on the A1 heading for home. Eventually he caught me up and I had a hoot of a game pulling in front of him and then flooring it so it covered his car in soot. As they say, if you cant smoke em' choke em'! Anyway this game ended with a phone call that described sparks coming from the rear of the car. Needless to say the rest of the journey was spent @ 50mph.
After investigating the next day there was jingle on the rear right wheel. Turns out it snapped the brake pad pin that holds the clip in so the clip was jingling. £3 kit from the local motor factors fixed this.
A few days passed and the car was running lovely, so I decided to clean the engine bay a bit:
And found this!! Trip to the welders needed lol
Anyhoo I didn't really clean the engine as they are generally greasy anyway so I just did around the engine bay and the bulkhead.
Let it dry and set off for my Dads, got down the road and my brakes failed - forcing me to rip up the handbrake to avoid the rear of a learner! Not to self: Handbrake is §§§§§ hot!
After a few days of puzzling and a second hand servo I threw in the towel and rang Steve, who appointed me to the fact the T piece along the servo hose should have a small vac hose in it. DOH! Found it down the back of the engine......
My basic plans for this car are to give it a major clean up, it was a "mobile mechanics" car so it is in dire need of a valet. Lacquer peel has also attacked the front, and seeing as my bro now has his own spraying premises a full respray could be on the cards at a later date. If the parts crop up - manual conversion too!
Post 590578 by Palmer on 2013-03-31 00:07:33
Every 940 needs a substantial horn of course.....
Single air horn, ive gone for the stealth look with everything being completely hidden under the headlight / in the bumper
Sounds the tits!
[video=youtube;lPAqW3r4tAI]http://www.youtube.com/watch?feature=player_embedded&v=lPAqW3r4tAI[/video]
Post 590579 by Palmer on 2013-03-31 00:12:23
Installed my catch tank today....
With which came the new intake
Fuel Pump Mods
Turned the fuel screw in a little. Its pictured here with the yellow markings on
Simply wind it in a few turns and tighten the jab nut back up. Obviousely there is an element of danger, being a rotary pump it can "run away" and rev sky high until it pops a piston in ya face! However im still at stock boost, so a few turns just gives it some more oomph. Ill set this up properly, including idle control etc when I up the boost. (Checked the turbo today, no shaft play at all @ 185k miles!!!)
Next I modified the LDA, located on top the pump. The idea is to liven the ole' bus up a bit and make it more driveable / quicker to take off.
Remove the 4 screws on the lid and it will look like this
Carefully peel the rubber diaphragm up and get a finger under the metal disc either side, and gently pull up. Be gentle as if you use too much force, it will knacker the dowel that rides on the fuel pin.
It should then look like this
There is a plastic washer in their, put it somewhere safe, like in the bin!
Take out the fuel pin and look at the mark that's been made by the dowel riding it
Removing the plastic washer allows it to ride all the way to the bottom thus injecting more fuel per (longer) stroke, crank the star wheel (gear like object) down a few turns. This reduces the tension on the diaphragm and allows it to inject more fuel at a lower boost setting. It does increase smoke though. This can be fine tuned with the jab nut / screw on top of the LDA
Before putting the Pin back in, note it is a shaft with an eccentric cone at the lower end. Rotating the pin to the more aggressive side (right had side in the pic) also increases the amount of fuel. It can be ground with a dremel or some sort to make it had a deeper ramp. My opinion is personally, get it done professionally. It needs to be 100% smooth for perfect fuelling and also the tolerances are minute, to an engineering level. So it will be better for performance if you get a pre ground one which is already at the limit, rather than guessing.
Overall: the car is **** hot! I need to fine tune the LDA with the screw on top as its smoking like a trooper on pull off (note: Black smoke = unburnt fuel = waste!)
But yeah, I am impressed with how jusy turning up the fuel makes it more lively. A lot more driveable is the expression id use, less throttle needed to get upto motorway speeds etc. And the auto box seems even more at home @ WOT.
Post 590582 by smithy on 2013-03-31 00:22:45
Nice build thread mate keep it going
Post 590583 by c70geoff on 2013-03-31 00:23:24
nicely done fella, look forward to seeing how this one progresses
Post 590629 by T5frankie on 2013-03-31 10:40:20
why is it not wearing the volans you have?
Post 590634 by Kingsford G on 2013-03-31 10:56:10
Nice buy mate and that horn is sick lol
Post 590656 by Palmer on 2013-03-31 11:57:31
Cheers guys, im really looking forward to upping the boost muaha!
Volans wont fit without £300 spacers Frankie :/
The horn is epic, lets everyone know of your presence lmao
Post 595140 by Palmer on 2013-04-10 15:03:45
Decided to rust proof the areas of the engine bay that are prone to corrosion. Aka the battery area and washer bottle area and chassis legs (I think lol)
Also, to give an idea of smoke - heres just revving:
[video=youtube;ZgdeRn359Sg]http://www.youtube.com/watch?v=ZgdeRn359Sg&feature=youtu.be[/video]
Post 595144 by M-R-P on 2013-04-10 15:23:06
Haha, James Bond will be so proud :D
Sounds nice. Good work ;)
Post 595193 by T5frankie on 2013-04-10 18:45:00
well done mate
Post 595231 by iancho on 2013-04-10 20:56:35
Your doing well mate, keep it up ! :B_thumb:
Post 595842 by Palmer on 2013-04-13 10:11:58
Decided to make a bracket to mount the catch tank on so it was more "flush"
And in place
Post 595895 by martybelfastt5 on 2013-04-13 13:33:39
great write up watching on voc too:B_thumb:
Post 597050 by Palmer on 2013-04-16 10:40:05
Just realised I never posted the mileage!!
Post 597220 by iancho on 2013-04-16 20:27:53
Some serious miles mate... Nice one :B_thumb:
Post 597412 by Rudy on 2013-04-17 16:14:40
Good looking project, always had a thing for these volvo's, Had a work car back in 2009 but 2.3 petrol, went side ways like a charm.. :D
Keep up that good work..
Post 600352 by Palmer on 2013-04-25 19:17:42
This arrived yesterday
Set of new discs and pads, drive belts, auto gbox service kit, oil filter and a set of glow plugs.
Will be fitted with an engine flush, new oil, new ATF, and new diff oil.
Also tested this today
Just a mock fitting. Currently its back out and im filling in the right hand side as you can see it slope. Also the finish is pretty poor just a quick splash of paint to bring up any blemishes. Cig lighter will be relocated to the centre console.
Post 600355 by 1112lewis on 2013-04-25 19:27:52
Finally got chance to read through this! You do love the dremel! Best tool ever.
Post 600362 by JamesT5 on 2013-04-25 19:41:48
[QUOTE=Palmer;590577]I'm going to use this space to document various happenings / doings to my newly acquired 940 diesel. Its a 2.4L straight six turbo diesel intercooler (D24tic)
My basic plans for this car are to give it a major clean up, it was a "mobile mechanics" car so it is in dire need of a valet. Lacquer peel has also attacked the front, and seeing as my bro now has his own spraying premises a full respray could be on the cards at a later date. If the parts crop up - manual conversion too![/QUOTE]
Just seen this same post on VOC. :D
Post 600390 by Palmer on 2013-04-25 20:18:37
Dremels are good little tools, but don't get me wrong... no replacement for a disc cutter.... haha
Post 600582 by 1112lewis on 2013-04-26 15:48:26
lol!
Post 600891 by Palmer on 2013-04-27 15:51:53
Few more vids for ya
Smoke on acceleration:
[video=youtube;KiISgHTURIo]http://www.youtube.com/watch?v=KiISgHTURIo&feature=youtu.be[/video]
Post 600894 by Palmer on 2013-04-27 15:52:31
And this was meant to be a smoke on foot braking but ended up slipping the rear a bit lol
[video=youtube;NiIEl-Q2ZGs]http://www.youtube.com/watch?v=NiIEl-Q2ZGs&feature=youtu.be[/video]
Post 603972 by Palmer on 2013-05-08 22:32:04
Relocated the cig lighter with a nice flashy 3 soc one and usb for phone charging!
I've given the gauge holder to my brother to finish, was getting on my nerves lol
Post 605107 by Palmer on 2013-05-12 14:15:38
Yesterday saw me invest the first "substantial" amount of money in "Sooty"
The days work included:
- Stripping all 4 brakes and cleaning them up, fitting new discs and pads. It was evident that they hadn't been cleaned in a long time. However, at 187k, only one sticky calliper was found, on the rear and it freed up with some pedal pumping.
- Replacing all 6 (yes, 5 and 6 as well!!!) glow plugs.
- Running some engine flush through, and then an oil + filter change.
- Servicing the auto gearbox with a new filter and fresh fluid.
- Draining the diff and fresh oil once again.
- Coolant flush and refill.
The work begins:
New rear discs + pads
New front discs + pads
Servicing the auto box
The rear diff
Found all 6 glow plugs to be black like this, confirming they were ALL not working one bit! No wonder it sounded rough as §§§§§§§§s on a cold start!
And for those still pondering, this is how you change 5 + 6!!!
It was also the first time id been under Sooty, and I confirm that the MOT it received was in fact more bent that a roundabout! I always had my suspicions because of the battery tray area rust and unsecured tray itself.
Whilst having a nosey I found:
Minor oil leak on the auto box cooler
Almost everything rubber at the front perished (sway bar mounts, bushes etc)
No cat, unsure as to whether it should have one or not
Hole in back box (confirmed by soot EVERYWHERE!!!)
Generally rusty (surface only)
So on the increasing list a manual conversion is confirmed (why fix the leak when its a good excuse!)
And probably some better mounts / bushes etc. The engine also has a massive amount of rocking in it, if you wobble it its like jelly. So probably solid mounts too, been told that's good for power :D
Waxoyl the underneath will also be on the list.
I think its safe to say its been neglected, but its had the "essentials" covered.
Ciao for now :D
Post 609423 by Palmer on 2013-05-23 16:37:31
Boost gauge....
Yes, I know its on the passenger side! I can still see it though as I have my seat all the way back.
When I get an EGT gauge I will order a holder that's angled... if I can find one lol
Post 616368 by V70 Graham on 2013-06-14 16:38:50
Good work, that water is dirty ! M-R-P gave my mats the once over last time I was at his, I can't believe how much dirt those cleaners get out.
Post 619048 by Palmer on 2013-06-22 22:47:18
Oh yeah the stuff they get out makes you think twice about eating a chip you dropped on your seat lmao!
LED backlighting on the dials.... :)
Post 621125 by Palmer on 2013-06-29 19:58:43
Had a little trouble installing this, got confused with the wires! When it said ignition feed I didn't realise it meant from the ignition switch, aka a thick red cable. I was using the cig lighter 12v... Kept blowing fuses. So beefed up the wires and done it right!
[video=youtube;1N9vBcShw84]http://www.youtube.com/watch?v=1N9vBcShw84[/video]
Kudos to Mike (Alder) for pointing me in the right direction! Seriousely owe this guy so much - hes now dubbed "the electrical guru" or TEG for short ;)
Did make me laugh when I asked if I needed to beef up the grounding wire and his response was:
"Nah don't worry about the ground as the solenoid is grounded through the engine block back to the battery, I doubt you could find a wire thicker than the chassis rails to be honest...... "
LMFAO
Post 632414 by AndysR on 2013-08-04 14:21:13
Nice work, exhaust sounds good :)
Post 632517 by Palmer on 2013-08-04 21:29:38
Hehe sounds epic lol
Post 636165 by Palmer on 2013-08-16 22:56:09
Right...
Not really been updating much due to the fact I've been busy with work. Came out of training and have been smashing all the overtime available and also been performing very well with my colleagues I started with. We where hired to rough some feathers and it seems to be happening... :)
So yeah basically some updates coming more often, a lot more money coming from work that I thought id ever get in this type of job, just got to finish paying off some things from when I was unemployed for a few months and then there will be some serious money invested in Sooty.
I've been getting depressed lately as there is so much work that needs doing but the car never fails to make me smile though, and always reminds me what its about. I love the tractor type chug it has on tickover, and that it goes silky smooth (6 cyl style!) under load. It truly is a fantastic engine.
Turns quite a few more heads than the petrol one ever did. Whether that's due to soot could or the scream it has at 5k I don't know, they are a very loud engine! And the turbo whistle with a cone filter is pretty awesome too!
So yeah, feeling motivated :D
Post 636589 by Palmer on 2013-08-18 17:46:15
Dunno about you lot but I get pee'd off not having a cupholder...
Original set up:
960 cupholder setup :D
Post 637764 by stribo on 2013-08-22 19:22:01
Good progress mate, coming on well.
Post 640051 by V70 Graham on 2013-08-31 18:53:31
100 times better with the dark headlining, good work.
Post 644150 by Palmer on 2013-09-14 16:56:42
Cambelt has now been done along with the pump belt!
Now however has developed one MONUMENTAL oil leak. On the turbo side everything below the head is covered in oil, and on the passenger side from the cam cover down.
Ordered a new gasket and hopefully get that fitted soon!
Week off too now so more updates....
