Dynamat a V70R...how much?
Post 602170 by LeeT5 on 2013-05-02 11:26:03
Hi peeps. I want to know roughly how much Dynamat to get so i can do the boot floor, and all 4 doors? Will 20sq/ft be enough or shall i get the 36sq/ft kit?
Post 602176 by M-R-P on 2013-05-02 11:39:33
If you say the doors are roughly 3' by 2', that's 24 sq foot for all four. tailgate is about 3.5' by 2', up to 31 sq foot.... think you'll need more than 36 sq foot mate.
Post 602186 by Harvey on 2013-05-02 12:36:39
And it will cost 1 MPG with the extra weight,then £20 in broken body clips :eye-poppi
Post 602572 by LeeT5 on 2013-05-03 23:40:24
[QUOTE=Harvey;602186]And it will cost 1 MPG with the extra weight,then £20 in broken body clips :eye-poppi[/QUOTE] All the door clips on my car are new. They don't break if your careful. apparently it makes a huge difference to intrusive exhaust sound and road noise coming into the car if you Dynamat the boot floor on a V70. Not only that, for me, with the sub in the tyre well, it should make a big difference to sound too! Gonna get 36sq/ft pack. I will do the doors first and use whats left in the boot. I am aiming for 7sq/ft of Dynamat per door and boot.
Post 602611 by Harvey on 2013-05-04 06:05:35
Yes I have heard people say the same thing about the V70 ,I guess I don't have this problem as I have a S60. Do you have a load cover fitted if so does that lower the sound level much or is it just to keep eyes out. A long time ago I fitted a car out with Dynamat it did cut the noise level down from outside but the noise level from inside went through the roof with a big incar install. What sort of weight is the pack .i do think someone does sell it as a kit for cars all pre cut.
Post 602646 by LeeT5 on 2013-05-04 10:07:52
No load cover. I removed it when the windows were tinted. I think it's less that the sound comes in and more that the road noise resonates through the floor of the car and is amplified by the large boot of the V70. How do you mean the sound level went through the roof? In a good way?
Post 602664 by Harvey on 2013-05-04 13:54:12
[QUOTE=LeeT5;602646] How do you mean the sound level went through the roof? In a good way?[/QUOTE] Fitted 2k worth of incar hifi.and that was 15 years ago.
Post 602667 by deliverydriver_dan on 2013-05-04 14:16:09
you can get dynamat spray for the doors as for the boot floor you will need to do all the rear panels as well as the tail gate, dynamat is designed to keep audio in the car and stop rattles and accustic resonance from causing unwanted noise in the car.I used to have a Vectra hatch with all doors sprayed with dynamat running 6.5 inch componets focals in front doors and rear doors powered by a dap 800 watt amp with 2 cerwin stroker 15 inch subs in the boot powered from a Sherwood xt 2000 watt amp. I used 36 sq ft of matting just for the boot floor,tail gate,rear quarter panels, stripped the whole hatch out to the metal to do it right made a big difference to the quality of music, we also used car matting on the rear wheel arches prior to putting the wheel arches liners back plus the underside of the rear of the hatch won a couple of awards at sound-offs for sound quality and staging and depth of volume you could hardly hear the sound out of the car
Post 602822 by Wobbly Dave on 2013-05-04 21:46:57
I have some spare sound proofing I need to get rid off. 20 quid delivered - self adhesive.
Post 602833 by Kingsford G on 2013-05-04 22:38:43
Y do u wanna hide that shiny paintwork mate?
Post 602846 by LeeT5 on 2013-05-04 23:09:32
[QUOTE=Wobbly Dave;602822]I have some spare sound proofing I need to get rid off. 20 quid delivered - self adhesive.[/QUOTE] How much you got? I'm interested.
Post 602936 by Squirtydog on 2013-05-05 08:29:34
[QUOTE=LeeT5;602646]No load cover. I removed it when the windows were tinted. I think it's less that the sound comes in and more that the road noise resonates through the floor of the car and is amplified by the large boot of the V70. How do you mean the sound level went through the roof? In a good way?[/QUOTE] I'd be interested to know how you get on. Some 'how to' pics would be really good. I have been wondering how much of the noise actually comes from the large boot floor itself. Thoughts? When I had 944s - if the boot floor carpet was left out, the increase in noise was huge. Pulling the load cover over does nothing for noise reduction however.
Post 602997 by Wobbly Dave on 2013-05-05 12:22:18
[QUOTE=LeeT5;602846]How much you got? I'm interested.[/QUOTE] I have 9 pieces left. Each piece is 50cm x 20 cm - so that 0.9m^2 which is just shy of 10 sq ft.
Post 603011 by LeeT5 on 2013-05-05 13:27:33
[QUOTE=Wobbly Dave;602997]I have 9 pieces left. Each piece is 50cm x 20 cm - so that 0.9m^2 which is just shy of 10 sq ft.[/QUOTE] Sold. Thanks Dave. Ill pm my addy later. Pm me your PayPal address please.
Post 603276 by LeeT5 on 2013-05-06 11:27:19
[QUOTE=Kingsford G;602833]Y do u wanna hide that shiny paintwork mate?[/QUOTE] Not quite sure what you mean?
Post 803229 by abdul on 2016-07-20 09:41:51
Did u dynamat your car
Post 803233 by LeeT5 on 2016-07-20 14:17:48
[QUOTE=abdul;803229]Did u dynamat your car[/QUOTE] Yes.
Post 803238 by abdul on 2016-07-20 22:43:11
[QUOTE=LeeT5;803233]Yes.[/QUOTE] Is it something worth doing . Is there a noticeable difference
Post 803278 by Ric@rdo on 2016-07-22 12:21:58
Did you cover the whole floor? I've been watching DIY on YouTube and some of them say that covering 20% of the surface it's enough to reduce the sound by 90%.
Post 803309 by LeeT5 on 2016-07-24 14:03:02
[QUOTE=abdul;803238]Is it something worth doing . Is there a noticeable difference[/QUOTE] yes there is a noticeable difference. The depth of bass from the Sub under the rear floor is enriched and has more presence with no distortion or vibration. Some songs by Tupac now make my ears bleed if cranked up :crazy: [QUOTE=Ric@rdo;803278]Did you cover the whole floor? I've been watching DIY on YouTube and some of them say that covering 20% of the surface it's enough to reduce the sound by 90%.[/QUOTE] You can see how much of the floor I covered in my Project thread. Pretty much, all of it. But have a look at the thread photos.
Post 818873 by Unknown on 2019-08-13 01:05:05
I use crystal 60 and carapills a lot , how much caripills and crystal 60 is to much , if I use a lb of 60 with some caripills my beer will taste like a ESB , should I leave it out if I do a lite beer. THX in advance
Post 819544 by CALICO on 2020-01-28 18:39:37
This stuff is as good as dynamat . You don't need to cover all of the inside of the door a 15 inch by 12" will reduce vibration significantly https://www.screwfix.com/p/bostik-flashband-grey-10m-x-100mm/57969
