Post 603973 by Cymro on 2013-05-08 22:33:57
The other day I decided to go get my Air-Con recharge as it wasn't blowing as cold as I thought it should. Now there were no flashing lights on the climate system on start up so wasn't aware of an issue just assumed the refrigerant was a bit low. From the word go things didnt look good, system was not holding consistent vacuum, and 0 reclaimed material. So the machine went into a pressure test and almost immediately confirmed a leak. So I asked the technician if they had some OFN so I could pressurise the system and try and narrow down the location of the leak. Fitted the nitrogen pipe and on turning it on loud whoosh from the compressor region. 2nd blast confirmed this, as they were unable to refill I wasnt charged. Tonight I searched the every join with a UV lamp to see if it was a seal, removed the under tray and check the compressor nothing, but the UV light showed up a large stain on the lower bracket of the radiator, ran hand up the low pressure pipe and its been rubbing on the mount and worn through. :( Now was this a common problem and subject to recall or have I just been unlucky. I guess im going to need to go to Volvo (FRF Swansea) for the new low pressure pipe and Reciver/Dryer (as i dont know how long the systems been open) but does anyone have a rough price for them? Thanks in advance
