Post 605424 by Al115 on 2013-05-13 13:33:17
... that makes them cost nigh on £100 rather than £12.50?
They come with the whole housing I think. Is this simply because Volvo wants to sell a big expensive part rather than a small cheap part, or is there a sound engineering reason for it?
Post 605501 by graemewelch on 2013-05-13 18:21:00
might be worth trying ford for the same part, might be a lot cheaper.
Post 605747 by LeeT5 on 2013-05-14 11:13:06
[QUOTE=Al115;605424]... that makes them cost nigh on £100 rather than £12.50?
They come with the whole housing I think. Is this simply because Volvo wants to sell a big expensive part rather than a small cheap part, or is there a sound engineering reason for it?[/QUOTE]
Isn't it because it comes as a complete unit? ie, Thermostat, housing and CTS?
Post 605759 by M-R-P on 2013-05-14 11:57:10
Jardon still has a stat for sale I think.
Post 605806 by Al115 on 2013-05-14 15:05:09
[QUOTE=M-R-P;605759]Jardon still has a stat for sale I think.[/QUOTE]
Yeah... I don't actually need one (yet) - mine is fine - I was just looking to do a "preventative" swap as part of a coolant change. But no harm in swapping for his one that's newer / less miles / I can clean first, given the hassle factor when it DOES go up the creek!
Post 606267 by partsforvolvos.com on 2013-05-15 10:07:51
i believe the later ones that are a moulded housing are scheduled with the cambelt change, but often missed by non volvo specialists.
i wouldnt think it is worth fitting a secondhand 'stat ? - might be worse than the one that comes off.
there are different ones as well depending on age.
