Thort id show this
Post 609834 by T5RatherAmusin on 2013-05-24 20:50:28
state of someones brakes from another forum. yes thats whats left of the disc in the middle :rotfl: Image
Post 609837 by V70 Graham on 2013-05-24 20:57:37
.....and the pistons !
Post 609838 by AndysR on 2013-05-24 20:58:09
Shocking! But then considering the ignorance of an alarming number of motorists these days not surprising!
Post 609840 by claymore on 2013-05-24 20:59:55
bloody hell, it's hard to believe that could happen between MOTs
Post 609848 by Kingsford G on 2013-05-24 21:04:21
I had one customer with the same situation where he only came cos was loosing brake fluid due to the pistone fully out.Unbelievable.
Post 609874 by JUDGENINJA on 2013-05-24 21:31:07
Nice...one way to loose some weight
Post 609877 by stribo on 2013-05-24 21:34:37
A good alternative if your car's not fitted with ABS. ;)
Post 609975 by zoidberg on 2013-05-25 00:43:45
[QUOTE=T5RatherAmusin;609834]state of someones brakes from another forum. yes thats whats left of the disc in the middle :rotfl: Image[/QUOTE] For a moment it I thought it was a pic of the ones I'ved just changed on my Fiat Doblo diesel.Only found out they were like that because the drive shaft shattered !!! Mine were a bit worse than that believe it or not, no interior rim whatsoever !:grumpy:
Post 609998 by jotter22 on 2013-05-25 08:08:48
I reckon he should just turn them and go again another couple of k in the other side! Tony.
Post 610013 by Gold 'N' Brown on 2013-05-25 10:22:26
[QUOTE=zoidberg;609975]For a moment it I thought it was a pic of the ones I'ved just changed on my Fiat Doblo diesel.Only found out they were like that because the drive shaft shattered !!! Mine were a bit worse than that believe it or not, no interior rim whatsoever !:grumpy:[/QUOTE] But how the hell do you let it get that bad? Not having a dig, as I'm not exactly disciplined when it comes to regular checks, but surely if you hadn't visually checked them in ages there must have been some warning signs from the braking performance (or lack thereof) or nasty noises long before it got to that stage? :eye-poppi
Post 610038 by p fandango on 2013-05-25 12:36:04
Theirs no way that's passed a legal mot within the last year for them to get that bad
Post 610039 by dirtybootz on 2013-05-25 12:46:43
Diabolical ! surely its ignorance !! :)
