Post 627955 by Bavers on 2013-07-22 20:06:14
Hi Guys.
With this hot weather I have noticed that my Air con on my 2000 ph2 V70 T5 is not working properly.
It has the dual zone climate control but with the Air Con on, it only blows cold from the passengers two vents but the drivers two vents just blows cool (defiantly not air con).
Does anyone know what the problem could be?
thanks
Nick
Post 627983 by johnnyb on 2013-07-22 21:08:43
Mine did this when the gas was running low but I think there are also some flaps somewhere in the depth of the dashboard that when faulty can cause this.
Post 627987 by stephenevans99 on 2013-07-22 21:10:04
Re-gas will do the trick.....these things take a Mahoosive 1000g of refrigerant.
Post 628703 by Volvo_Mad on 2013-07-24 21:17:06
try turning the temperature the same on both dials just a suggestion mate
Post 628809 by partsforvolvos.com on 2013-07-25 09:05:27
sounds like a flap motor is defective or in the wrong position - they can be re calibrated. does it go opposite if you change the settings to hot on the faulty side?
