Thermastat for S60R.
Post 628990 by stribo on 2013-07-25 21:01:03
The R overheated whilst Rachel was driving it home tonight, so looked into changing the thermostat, but PFV and EuroCarParts only list the thermostat and housing complete. As the housing comes apart, I'm sure it would be possible to change just the 'stat, but what one would I use? Any (sensible) ideas gratefully received.
Post 629013 by deathrider311271 on 2013-07-25 21:21:57
as far as im aware thats correct on the S60R, i personally would only use a volvo one as the aftermarket ones can be a bit hit and miss
Post 629020 by LiamT4 on 2013-07-25 21:26:12
Wasn't Al115 talking about these stats not too long back? (i could be thinking about totally the wrong person though)
Post 629022 by stribo on 2013-07-25 21:27:01
[QUOTE=LiamT4;629020]Wasn't Al115 talking about these stats not too long back? (i could be thinking about totally the wrong person though)[/QUOTE] Hopefully he'll see this thread
Post 629037 by Harvey on 2013-07-25 21:36:21
I think you are thinking of this one. http://www.vpcuk.org/forums/showthread.php?50714-What-is-magic-about-the-Phase-2-thermostats&highlight=V70+thermostat
Post 629040 by stribo on 2013-07-25 21:37:44
[QUOTE=Harvey;629037]I think you are thinking of this one. http://www.vpcuk.org/forums/showthread.php?50714-What-is-magic-about-the-Phase-2-thermostats&highlight=V70+thermostat[/QUOTE] That's the one, but doesn't answer my question.
Post 629041 by Harvey on 2013-07-25 21:39:12
Just to ask is the cooling fan running when it hot when the air con is switched off ?. I think the engine temp sensor is on the thermostat which I think goes to ecu which runs the fan.
Post 629044 by stribo on 2013-07-25 21:41:50
The fan was running yes, but Rachel wasn't even sitting in traffic, so the fan shouldn't have been needed. I think it just stuck shut, as by the time I got to the car 10 minutes later it was back down to normal temperature.
Post 629045 by graemewelch on 2013-07-25 21:41:54
hope your liners havnt let go. do want to scare you
Post 629048 by stribo on 2013-07-25 21:42:29
Liners are fine. :P
Post 629054 by Harvey on 2013-07-25 21:46:55
Has the water pump been changed ?.
Post 629056 by stribo on 2013-07-25 21:48:15
[QUOTE=Harvey;629054]Has the water pump been changed ?.[/QUOTE] Yep, made sure it was changed with the cambelt 10,000 miles ago.
Post 629057 by Harvey on 2013-07-25 21:48:49
Just thinking did the temp gauge move passed 12 o'clock or just stay there ?.
Post 629059 by stribo on 2013-07-25 21:49:59
It got right up to red.
Post 629061 by graemewelch on 2013-07-25 21:51:47
[QUOTE=stribo;629048]Liners are fine. :P[/QUOTE] take nothing for granted, costs nowt to do a compression test, if you dont have one i lend you one. check the fan works. check the thermostate the old fashioned way. drop in pot of boiling water
Post 629065 by stribo on 2013-07-25 21:54:03
[QUOTE=graemewelch;629061]take nothing for granted, costs nowt to do a compression test, if you dont have one i lend you one. check the fan works.[COLOR="#FF0000"] check the thermostate the old fashioned way[/COLOR]. drop in pot of boiling water[/QUOTE] But that's the thing, if I can take the thermostat out of the housing to check it, why can't I just buy the 'stat with having to buy the housing as well. :slap:
Post 629071 by Harvey on 2013-07-25 21:58:15
Are there any air bubbles coming up throught the coolant in the header tank it could have had a air (steam) lock after it got hot then as you say cooled down then ok again.
Post 629078 by merc85 on 2013-07-25 22:03:03
[QUOTE=stribo;629059]It got right up to red.[/QUOTE] Have a look at the stat, should be a insert type like this http://www.autopartoo.com/oem/gates/th35991.html if it is i will get you a price if you like, i can also get a price on a oe quality housing/stat if you like. The housing is number should be number 15 here }}}}}}}}}}}}}}}}}}}}}}} http://www.volvopartswebstore.com/showAssembly.aspx?ukey_assembly=241318&ukey_make=865&ukey_model=12009&modelYear=2004&ukey_category=7072&ukey_driveLine=483&ukey_trimLevel=11150
Post 629082 by stribo on 2013-07-25 22:12:23
I didn't see any when I restarted it, it drove the mile home fine after Rachel had stopped, I'm guessing the 'stats starting to go and want to change it before it gives up totally, was just hoping to be able to buy it on it's own rather than with the housing assembly.
Post 629093 by Harvey on 2013-07-25 22:39:36
Looking at the parts listing volvo did one upto -2001 then changed it 2002-2004 then changed it again in 2005- on years and changed that once aswell. The best bet I would say is see if the 2005- on year would fit as they would not have changed it for no reason I would guess ?.
Post 629098 by Harvey on 2013-07-25 22:58:38
Just thinking are the small rubber hoses that connect to the turbo steel pipes all ok at the back of the engine,I take it you are not low on coolant .
Post 629161 by stribo on 2013-07-26 06:37:11
No, coolant level is fine.
Post 631366 by stribo on 2013-07-31 22:57:59
Not happy to say the least. Tried taking the thermostat out to test it, and turns out the aux drive belt, p.a.s. pump has to come off to get to it!. So it's going go our indie to be done. It only took me 10 mins to change the 'stat in the C70.
Post 631367 by M-R-P on 2013-07-31 23:06:12
Ford ;)
Post 631399 by stribo on 2013-08-01 06:59:01
[QUOTE=M-R-P;631367]Ford ;)[/QUOTE] Bloody Volvo, Ford ones are easy to change, and you don't have to buy the housing as well.:P
