Post 635428 by Luke77980 on 2013-08-14 21:48:04
I'm really looking at getting a bit more power from my S60 T5 and my initial thoughts were remapping the ECU. Should I do any other modifications prior to this mod? I have already changed the filter to a a ITG panel filter.
Post 635437 by merc85 on 2013-08-14 21:56:11
[QUOTE=Luke77980;635428]I'm really looking at getting a bit more power from my S60 T5 and my initial thoughts were remapping the ECU. Should I do any other modifications prior to this mod? I have already changed the filter to a a ITG panel filter.[/QUOTE]
Where your approx area buddy? this may help.
http://www.rica.nl/contact.php
Post 635444 by Chad on 2013-08-14 22:11:09
Hi Luke,
what year is the T5 and what gearbox has it got?
What other modifications are you thinking of?
GRN offer quite a selection of remaps and modifications depending on your requirements.
Chad
Post 635453 by Luke77980 on 2013-08-14 22:21:07
its a 2003 2.3 T5 with a manual gearbox. I was thinking changing the exhaust but im not too sure what else to do.
Post 635455 by graemewelch on 2013-08-14 22:25:25
exhaust and 3" down pipe will make a good difference combined with a remap. that shouls get you around the 280 mark
Post 635582 by Chad on 2013-08-15 08:54:53
All depends what sort of gains/power you want from it??
I would say start with a map, they do become quite 'lively' with a map.
then if you want abit more grunt and ooomph, go for a 3"dp, and 2.5" cat back, a decent air intake, maybe a larger front mount intercooler and a custom map to suit.
Where are you based??
Post 635601 by Nutternick on 2013-08-15 10:29:36
HLM are doing a remap for my 1998 v70 t5 £150 BARGAIN
