DIY: Volvo 850 Cabin Filter Replacement (Video Tutorial)
Post 638170 by ProStreetDriver on 2013-08-24 04:29:02
Video tutorial on how to replace the cabin filter on a Volvo 850. This applies to both the sedans and wagons. The filter is located underneath the front cowl on the passenger side of the vehicle. There are also 2 types of cabin filters, so before you purchase a new filter, determine which type it is. Procedure: -open the hood and locate the filter on the passenger side of the vehicle under the plastic cowl -remove the 3 T-25 torx screws along the front of the cowl -once they are removed, pull straight up, and you will be able to see the cabin filter under the cowl -pull the cabin filter tab upwards and side forward -now remove the cabin filter out to the side of the cowl -reinstall new filter in reverse [video=youtube;t9ES7jAuw_c]http://www.youtube.com/watch?v=t9ES7jAuw_c[/video]
