Post 644529 by Daniel B on 2013-09-15 19:43:30
Hello all, I'm going to blame this on a 4 week old baby and lack of sleep...... Had a warning message on "Position bulb failure" I think it was, had it half a dozen times before, and a light thump on the rear light cluster has until now been bringing it back into life. Not this time though, so thought I would change the bulb.... Pulled out what I thought was the bulb, and turned out instead to be this little black plastic box, which also appears to have partially broken - notice only one plastic tab left in one of the holes, and then there was some clattering behind, and I extracted the 2 bits in the last picture - the nut may have just been there for some time I guess. The end result is now that where I had 1 positioning light working before on the drivers side, I now have none :slap: So my question is, should I just take it to the garage, and say "Here are the bits, here is the problem, can you please fix it?" Or is there a possibility I can retrieve the situation and fix it myself? I don't really understand what the little black plastic box does, as it doesn't appear to have any connectors, but then the other bulb is definitely no longer working, so it must be connected to that in some manner. Wish I had just left it for the time being, or taken more time over it, hindsight and all that - thought it would be a quick job. Not sure how easy it is to get to that top bulb anyway, as I think it is a way above the pull out cover in the rear, and also would be a way below the speaker cover (I think it's a speaker cover?) further up - I did not take it off to try at the time, thought I would probably break that too. I'm guessing that it's probably going to be a bit too involved now to resolve myself, but thought it worth asking in case someone had replaced something similar, or knew a good place to get a spare part - assuming I need one. I'm guessing I would need to take the whole rear light cluster off if I am going to fix it? [ATTACH=CONFIG]22558[/ATTACH] [ATTACH=CONFIG]22559[/ATTACH] [ATTACH=CONFIG]22560[/ATTACH] [ATTACH=CONFIG]22561[/ATTACH]
