Post 645737 by T5RatherAmusin on 2013-09-21 13:07:10
kinugawa stuff is fine. but youd prob have to redesign the rod too.....
as for that other cbv, wouldnt bother. stop being a cheap barstool! ;)
Post 645738 by jdavis on 2013-09-21 13:08:46
looks like they do quite a range, including volvo TD04.
Post 645749 by graemewelch on 2013-09-21 13:46:58
[QUOTE=T5RatherAmusin;645737]kinugawa stuff is fine. but youd prob have to redesign the rod too.....
as for that other cbv, wouldnt bother. stop being a cheap barstool! ;)[/QUOTE]
ive got ne choice to be tight. havnt worked for 13 weeks, only income ive got is off the exhausts i build. ive got a lot of mods to pay for between now and xmas.
Post 645763 by T5RatherAmusin on 2013-09-21 14:16:38
Y between now n xmas?
is it coz of shark custom?
If so. Youd prob be better off with the stock parts than these cheap ones. Do it right. Do it once.
Get it to best level you can then go remap.
I think they said theyd honour theyr deal price (which hasnt been confirmed yet ffs lol)
If u can make the date for whatever reason....
Post 645776 by graemewelch on 2013-09-21 16:15:30
i want it done by xmas cause thats about the time i expect to be driving again. im taking advantage of the fact i cant drive and doing everything to the car while its of the road. im only going down the shark route if i fit a new turbo other wise its staying with the rica stg 2. once im back to work i cant bebother with doing a bit here a bit there. this way i can take my time and do it once the right way not the rushed way.
after 80k the actuator wont be as strong as it once was hence changing it.
Post 645778 by smithy on 2013-09-21 16:23:24
[QUOTE=graemewelch;645776]i want it done by xmas cause thats about the time i expect to be driving again. im taking advantage of the fact i cant drive and doing everything to the car while its of the road. im only going down the shark route if i fit a new turbo other wise its staying with the rica stg 2. once im back to work i cant bebother with doing a bit here a bit there. this way i can take my time and do it once the right way not the rushed way.
after 80k the actuator wont be as strong as it once was hence changing it.[/QUOTE]
I would watch what you buy because if you buy a tighter actuator the bcs might not like it and cannot control the boost properly with your standard turbo.
Post 645779 by graemewelch on 2013-09-21 16:31:54
i will prob end up with a forge one but thought would ask to see if anyone had tried one of these befor.
Post 645780 by p fandango on 2013-09-21 16:41:00
[QUOTE=T5RatherAmusin;645737]kinugawa stuff is fine[/QUOTE]
i've got a Kinugawa exhaust turbine & waiting for a professional verdict on it as they chewed the locking nut up ALOT trying to balance it
Post 645787 by Biff on 2013-09-21 17:25:41
I've got a forge one. At the time of looking t5pete had trouble with a jap one. Got no complaints at all, although mines standard boost etc at the mo.
Post 645789 by smithy on 2013-09-21 17:49:30
If you want to stick a different actuator to run higher boost I would try a -31 actuator
Post 645792 by graemewelch on 2013-09-21 18:10:52
think ill get a forge when the time comes. mines prob ok just want the car perfect when gose back on the road. that that its rough or anything just me getting carried away and wanting to change everything thats servicable.
Post 645799 by Jamest5r on 2013-09-21 18:28:07
T5Pete had one on his 18t, he threw it in the bin, nuff said
Post 645830 by graemewelch on 2013-09-21 19:50:09
thats exactly the kind of info i needed to hear. ill get saving for a forge one
Post 645849 by Jamest5r on 2013-09-21 20:21:01
http://www.vpcuk.org/forums/showthread.php?51006-Holy-moley&highlight=
Same one? im guessing as pete's spelling aint up to much :)
