Post 645771 by Marc Lenssen on 2013-09-21 15:10:52
Hi All,
Been trying to locate a nasty metallic rattle in my 2002 S60 manual. The car has done about 140K miles and when I bought it I thought the rattle would be linked to old suspension parts. Having sorted the old suspension (new shocks, links, arms etc..) the nasty rattle is still there. I can't find anything in the suspension that would cause a nasty rattle, except maybe old drive shafts?
But have a look at this and see if yours does the same? Could it be the source of my noise?
[video=youtube_share;dDisqogPNRo]http://youtu.be/dDisqogPNRo[/video]
Thanks,
Marc
Post 650867 by kyekye09 on 2013-10-08 00:40:08
my s60 does the same but its a 2004 t5 have you found a solution yet...???
Robert
Post 650868 by M-R-P on 2013-10-08 00:42:28
How did I miss this?
Mine does this too (the gear linkage thing - it's normal), I doubt this is the cause of the noise. Have you checked the hub bolts? they can cause a knpck/rattle when changing gear and coming on and off the throttle. The subframe bushes can also make a bit of noise when worn but I doubt that's the problem. There's lots of things that can mislead you to think there's a problem - seatbelt buckle rattling on the trim, bottle rattling off the seat runner (underneath) etc.
Post 650870 by kyekye09 on 2013-10-08 01:39:35
ive done the meyle hd arms and ball joints hd droplinks and the shocks were replaced by previous owner for oem Volvo units about 8months ago but mine isn't doing it while im changing gear it does it small bumps.. speed bumps... and pot holes anything upsets it lol
Post 650883 by M-R-P on 2013-10-08 08:18:47
Possibly a loose heatshield on the exhaust?
Track rod ends?
wishbone bushes?
could even be something daft like the rad fan has worked loose.
Post 650906 by Marc Lenssen on 2013-10-08 10:40:29
Tie rod ends are my next check, and the left side drive shaft. Mine moans and rattles when the left front wheel goes through a dip in the road.... or rattles when driving on cobble stones.... very annoying and at times embarrassing :-)
I can't cause the suspension to make any noise at standstill and pushing the car down or up... nor do I feel any play in the wheels when o the ground... I got the new hub bolts for the xc90 with the rubber stops, no difference.. When redoing the shocks and arms and links I hope I did not somehow mess up the drive shaft.... or mount something wrongly... but at the moment I have no time nor space to take the suspension on that side apart again and check everything....sigh...
The quest for the noise continues....
Marc
Post 650909 by M-R-P on 2013-10-08 10:43:33
It's very easy to damage the inner CV when doing the arms and shocks on these cars, I would suspect that's what you may have done :(
16000 posts...
...time for a lie down :)
Post 650940 by kyekye09 on 2013-10-08 12:11:06
so my next try will be inner and outer track rods:slap:
Post 650942 by M-R-P on 2013-10-08 12:12:31
Just garb them and give them a wiggle, you should be able to tell if they're shot. Not expensive to replace but a pain in the arse to do.
Post 650945 by kyekye09 on 2013-10-08 12:30:42
will give it a check on the next day off
thanks for your input thus far lol.... no doubt I will be back:wallbash:
Post 650946 by stribo on 2013-10-08 12:33:55
I wouldn't be surprised if it was subframe bushes, these cars are getting on a bit now, so there's bound to be a bit of movement.
Post 650963 by kyekye09 on 2013-10-08 14:31:54
[QUOTE=stribo;650946]I wouldn't be surprised if it was subframe bushes, these cars are getting on a bit now, so there's bound to be a bit of movement.[/QUOTE]
how and where can I get hold of said bushes and is there a how to on fitting them....????
Thanks in advance
Robert
Post 650965 by graemewelch on 2013-10-08 15:00:48
get some bush inserts. also ups man has just been
Post 650966 by stribo on 2013-10-08 15:06:01
[QUOTE=graemewelch;650965]get some bush inserts.[COLOR="#FF0000"] also ups man has just been[/COLOR][/QUOTE]
Does that mean what I think it means?
Post 650968 by graemewelch on 2013-10-08 15:14:04
[QUOTE=stribo;650966]Does that mean what I think it means?[/QUOTE]
it sure dose. ive been kind to. i didnt go mad with the tape. i have been known to wrap them up so well that i could take hours to unwrap
Post 650969 by kyekye09 on 2013-10-08 15:14:16
bush inserts ups man:confused:lol
Post 650975 by stribo on 2013-10-08 15:34:31
[QUOTE=graemewelch;650968]it sure dose. ive been kind to. i didnt go mad with the tape. i have been known to wrap them up so well that i could take hours to unwrap[/QUOTE]
Wouldn't have mattered, I'd have got Rachel to unwrap it as payback for her wrapping. ;)
Post 651193 by graemewelch on 2013-10-09 11:49:00
[QUOTE=stribo;650975]Wouldn't have mattered, I'd have got Rachel to unwrap it as payback for her wrapping. ;)[/QUOTE]
theres always next time
Post 651206 by stribo on 2013-10-09 13:14:56
[QUOTE=kyekye09;651149]is this the bushes that I need...???
http://www.partsforvolvosonline.com/product_info.php?products_id=5345
http://www.partsforvolvosonline.com/product_info.php?products_id=5344
where do they go...????
any special tools needed...????[/QUOTE]
That's the ones Bud, they go where the subframe bolts to the floorpan, and front cross member, I don't know how hard the old ones are to get out, but the new ones should wind in when you tighten the bolt.
Post 651378 by kyekye09 on 2013-10-09 23:53:08
:redface:[QUOTE=stribo;651206]That's the ones Bud, they go where the subframe bolts to the floorpan, and front cross member, I don't know how hard the old ones are to get out, but the new ones should wind in when you tighten the bolt.[/QUOTE]
this will probs make more sense when I get under the car.... thanks bud...
do I need to drop the sub frame:redface:
Post 651382 by stribo on 2013-10-10 00:08:22
[QUOTE=kyekye09;651378]:redface:
do I need to drop the sub frame:redface:[/QUOTE]
No, just do one at a time. ;)
Post 651501 by Fubar1977 on 2013-10-10 18:10:50
Would that be the bushes in this video?
http://m.youtube.com/watch?v=eGEfWjxISyE
Post 651563 by kyekye09 on 2013-10-10 22:26:45
im hoping so.... would these inserts stop the rattle...???? and I take it the bolts are single use and I will need to go to main dealer for replacements...???
Post 651568 by graemewelch on 2013-10-10 22:49:02
forgot to mention bolts in pm. if was me id buy high tensile 12.9 bolts. inserts will fix sloppy bushes. easy to fit to. be cheaper than new bushed too
Post 651590 by kyekye09 on 2013-10-10 23:39:26
[QUOTE=graemewelch;651568]forgot to mention bolts in pm. if was me id buy high tensile 12.9 bolts. inserts will fix sloppy bushes. easy to fit to. be cheaper than new bushed too[/QUOTE]
cheers Graeme and will get pics of your down pipe up asap well pleased buddy thank you
