Post 646135 by stribo on 2013-09-22 20:52:54
Being the busy boy I am (take note Flying Brick :P) I changed the front pads and discs on the R this morning, having done my exhaust.
The outer part of the disc was just worn:
The inner though looked a lot worse:
Post 646143 by M-R-P on 2013-09-22 20:59:35
Looks like mounting problems or sticky inner calipers. There's deffo not been full contact there for some time mate.
I seem to remember you saying "why would I worry about what size the brakes are on my wife's car..." Well you've got more than the size to worry about now lol.
My 336 brakes are working perfectly by the way :bud:
Post 646144 by stribo on 2013-09-22 21:00:50
Your's have only been on 5 minutes, see how they look after 9 years. :P
Post 646152 by Harvey on 2013-09-22 21:08:38
The R calipers don't move on sliders,my guess would be the alu under the stainless guides have lifted the guides up (bit of corrosion)and nipped the pads in the calipers which would hold the pads too tight to let them move/float around as they should.
Were the inner pads a bit harder to remove ?.
Post 646161 by M-R-P on 2013-09-22 21:22:34
[QUOTE=stribo;646144]Your's have only been on 5 minutes, see how they look after 9 years. :P[/QUOTE]
There's no way those pads/disks were there for 9 years dude.
There's no way my car will be about in 9 years any way - that'll be about 400k!
Post 646162 by stribo on 2013-09-22 21:25:15
[QUOTE=Harvey;646152]The R calipers don't move on sliders,my guess would be the alu under the stainless guides have lifted the guides up (bit of corrosion)and nipped the pads in the calipers which would hold the pads too tight to let them move/float around as they should.
Were the inner pads a bit harder to remove ?.[/QUOTE]
No, they fell out. I cleaned the pins up with some emery, so hopefully there won't be a repeat problem.
Post 646164 by stribo on 2013-09-22 21:26:45
[QUOTE=M-R-P;646161]There's no way those pads/disks were there for 9 years dude.
There's no way my car will be about in 9 years any way - that'll be about 400k![/QUOTE]
No but the calipers have. 400K, just run in. :P
Post 646167 by Harvey on 2013-09-22 21:31:19
[QUOTE=stribo;646162]No, they fell out. I cleaned the pins up with some emery, so hopefully there won't be a repeat problem.[/QUOTE]
Did the pistons all push back in ok and dust seals ok. The car hasn't stood up for any length of time before you got it.
Very strange both sides did the same thing.
Post 646170 by M-R-P on 2013-09-22 21:31:47
[QUOTE=stribo;646164]No but the calipers have. 400K, just run in. :P[/QUOTE]
Maybe on a fwd... on an R it'll have been made into dogfood tins by 200k ;)
My calipers were on Steves R for months and were 2nd hand when he got them :blahblah:
Post 646171 by stribo on 2013-09-22 21:32:40
I'm guessing the car was stood up for a while before we bought it, all pistons went back fine, and the rubbers looked good.
Post 646759 by graemewelch on 2013-09-24 23:15:00
have you binned those discs yet. could use them for a moc up
Post 646792 by stribo on 2013-09-25 07:10:17
[QUOTE=graemewelch;646759]have you binned those discs yet. could use them for a moc up[/QUOTE]
Nope they're sitting in the back of the Cougar.
Post 646831 by M-R-P on 2013-09-25 08:52:19
[QUOTE=stribo;646792]Nope they're sitting in the back of the Cougar.[/QUOTE]
Careful - they might fall through with all that tinworm:haha::smileypul
Post 646852 by stribo on 2013-09-25 10:14:37
[QUOTE=M-R-P;646831]Careful - they might fall through with all that tinworm:haha::smileypul[/QUOTE]
Only got one patch of rust, but it's on the sill.:P
Post 646935 by graemewelch on 2013-09-25 16:04:47
you got any plans for them. could come in handy for phase one brake conversion i want to build. xc90 calipers with 330mm discs.
Post 646958 by stribo on 2013-09-25 17:53:42
No you can have them, I like the sound of your conversion, would go well on my C70.;)
Post 647176 by graemewelch on 2013-09-26 10:20:52
thats great ill pm you. ill sort you a set when they are done
