Post 652745 by t5 pete on 2013-10-14 23:19:16
Bad news on the fly wheel I thought you had sorted it I carnt remember off the top of my head now but what was the difference between the two
Post 652748 by merc85 on 2013-10-14 23:28:26
[QUOTE=t5 pete;652745]Bad news on the fly wheel I thought you had sorted it I carnt remember off the top of my head now but what was the difference between the two[/QUOTE]
The early flywheels have hollowed out holes around the flywheel, the later obd2 cars have raised lugs, You can reverse the polarity ie change the crank sensor plug round the other way this will enable you to start and run the car, But since the weather has got colder i think the signal to the ECU has got to weak when cranking so she takes ages to fire. When
cranking there is No spark. (until the flywheel) has done sufficant amounts of revolutions. Eveything electrical has been changed for new OE parts.
Post 652749 by Kingsford G on 2013-10-14 23:54:43
The signal friquency is to blame I suppose.Hope to hear the good new mate.
Post 652753 by p fandango on 2013-10-15 03:40:32
[QUOTE=merc85;652748]The early flywheels have hollowed out holes around the flywheel, the later obd2 cars have raised lugs, You can reverse the polarity ie change the crank sensor plug round the other way this will enable you to start and run the car, But since the weather has got colder i think the signal to the ECU has got to weak when cranking so she takes ages to fire. When
cranking there is No spark. (until the flywheel) has done sufficant amounts of revolutions. Eveything electrical has been changed for new OE parts.[/QUOTE]
i hate to be the bearer of bad news, but what you've just said was actually a Volvo recognised tip to its engineers. Which if there was any adverse effects from doing this (like the slow starting your having) i doubt they'd would be happy with, they'd of just ordered the correct crank speed position sensor. Have you had the codes read to see if anything is logged?
Post 652755 by V70 Graham on 2013-10-15 03:44:07
Hopefully some good news today mate.
Post 652770 by merc85 on 2013-10-15 11:08:03
[QUOTE=p fandango;652753]i hate to be the bearer of bad news, but what you've just said was actually a Volvo recognised tip to its engineers. Which if there was any adverse effects from doing this (like the slow starting your having) i doubt they'd would be happy with, they'd of just ordered the correct crank speed position sensor. Have you had the codes read to see if anything is logged?[/QUOTE]
NO CODES, if you have any other suggestions please feel free. ;)
Post 652771 by p fandango on 2013-10-15 11:17:26
[QUOTE=merc85;652770]NO CODES, if you have any other suggestions please feel free. ;)[/QUOTE]
if i had any ideas mate i'd let you know. I'd of thought if the ecu was refusing to start because of a lack of signal from the crank position sensor it would of logged it
not trying to put you down, thats just how i see it i'm afraid
Post 652773 by merc85 on 2013-10-15 11:31:24
The ecu does not log any codes from a non start situation, all i know the there is no spark from cold and the wiring/connectors to and from Injector driver, cam crank and other associated relays, sensor's are good, all other sensors and coil/module leads plugs cap lalalalala lol have bin replaced
The flywheel is the only thing that is incorrect on the vehicle, so that being the case i think its worth a shot.
Post 652775 by M-R-P on 2013-10-15 11:46:07
This is starting to sound like the red one all over again...
What components did both cars had in common...?
Engine?
Fuel pump?
Is it possible that you've singled out a known issue and focused on that rather than looking into other causes?
Just a thinking out loud here and feel free to shoot me down at any time mate.
Post 652787 by V70 Graham on 2013-10-15 13:03:53
[QUOTE=M-R-P;652775]What components did both cars had in common...?[/QUOTE]
.....the owner, sorry Gav it might be you !
Post 652798 by merc85 on 2013-10-15 13:35:47
[QUOTE=V70 Graham;652787].....the owner, sorry Gav it might be you ![/QUOTE]
Think your right^^^^^^^^^^^, Flywheel is the only common factor, fuel pump brand new walbro
Post 652812 by craigoodwood on 2013-10-15 15:11:11
on the bright side, if it is the end at least you'll get to drive the nissan more :):)
