2002 s60 t5 Idle at 665 rpm's
Post 653926 by Marc Lenssen on 2013-10-19 11:08:26
Hi All, I have always felt that my idle is a bit on the low side....feels a bit rough... I have new maf, boost pressure sensor, coils, plugs, air and fuel filter. Just received my small odbII Bluetooth thingy and through the Torque app I can finally see a digital read out of the rpm's: 665.... is that normal or does it sound a bit low? No fault codes at all.... Thanks, Marc
Post 653927 by M-R-P on 2013-10-19 11:24:16
my 2003 T5 went from 750 to about 665 after having my DIM changed. I put it down to a software change. nightmare if you polybush your engine mounts, shakes your fillings out lol.
Post 653929 by T5RatherAmusin on 2013-10-19 11:49:55
Sounds bout right tbh. Think mine settle at bout 650 Propper Oil change may help
Post 653944 by Marc Lenssen on 2013-10-19 12:57:10
Ok, so nothing wrong there....just sounds and feels better when slightly higher...Can the dealer set it?
