mbc and dump valve questions
Post 654200 by t5steve on 2013-10-19 22:23:54
gave my old mbc to a friend to fit on his manual T5 but can't remember which connection goes where so 1st question is where does the bottom connection go to and where does the side connection go to Image next question may sound silly (and probably is) but does a dump valve have to be upright to work...........ie piston facing up thanks in anticipation as always will make it a lot easier to fit them in morning for him if we know where everything goes
Post 654205 by darzmat on 2013-10-19 23:11:00
my dump valve is on its side, so anyway should be fine. not a clue about the mbc
Post 654209 by Rnash2002 on 2013-10-19 23:18:19
The outlet to the right of the picture goes to the actuator.
Post 654228 by M-R-P on 2013-10-20 07:19:07
2nd shortest thread in history.... oops! 3rd now lol.
Post 654236 by stribo on 2013-10-20 08:32:21
[QUOTE=M-R-P;654228]2nd shortest thread in history.... oops! 3rd now lol.[/QUOTE] Must be time to go off topic, just to bulk it out a bit.;)
Post 654237 by M-R-P on 2013-10-20 08:43:26
[QUOTE=stribo;654236]Must be time to go off topic, just to bulk it out a bit.;)[/QUOTE] errrr ok... you bent a rod yet Steve?
Post 654238 by V70 Graham on 2013-10-20 08:44:16
......or fitted that intercooler ?
Post 654257 by stribo on 2013-10-20 10:46:05
No, and no.
Post 654262 by oblark on 2013-10-20 12:07:44
[QUOTE=M-R-P;654237]errrr ok... you bent a rod yet Steve?[/QUOTE] He will just give him time :)
Post 654263 by AndysR on 2013-10-20 12:20:36
A thread go off topic on VPC...? Never..
Post 654272 by stribo on 2013-10-20 13:07:21
[QUOTE=oblark;654262]He will just give him time :)[/QUOTE] You're confusing me with someone else, I can resist the temptation to keep winding my bleed valve out to get more boost. :P
Post 654274 by t5steve on 2013-10-20 13:10:31
as usual thanks for the info..........................didn't think for a minute this would go off topic......................................
Post 654283 by M-R-P on 2013-10-20 13:29:37
[QUOTE=stribo;654272]You're confusing me with someone else, I can resist the temptation to keep winding my bleed valve out to get more boost. :P[/QUOTE] Is it a bit "tappy" yet? ;)
Post 654335 by oblark on 2013-10-20 15:40:18
[QUOTE=stribo;654272][COLOR="#FF0000"]You're confusing me with someone else[/COLOR], I can resist the temptation to keep winding my bleed valve out to get more boost. :P[/QUOTE] No, he doesn`t drive a gay gold C70 :)
