Brake light issue v70 d5
Post 657721 by v70d5 on 2013-11-02 16:46:34
Hello all, The side brake lights no longer work but the top brake light does. The bulbs and fuses (after being replaced due to attaching a trailer blew one of the fuses) are OK. When the brake pedal is pressed with no key in the ignition, I can here and feel a relay working at the Rear Electronic Control Module. All of the relays are black so I cannot easily determine if the relay I have identified is the correct one (original is blue I believe). Does anyone know if the RECM has names for each relay, as I will need to remove the rear left-hand luggage panel in order to gain access to the relay in question? Also, if the relay is clicking then this indicators that it is OK, correct? If yes, then what else could have caused this problem?
Post 657728 by mikealder on 2013-11-02 17:46:31
Double check fuse 3 and 14 in the REM as both of these feed the rear brake lights but have nothing to do with feeding power to the center brake light, if both fuses are OK you will need to pull the right rear trim panel out to get access to the REM, the brake light relay is idented RMI5 - Mike
Post 658010 by v70d5 on 2013-11-04 11:00:31
Tks Mike. I have checked all fuses in all three fuse boxes and they are all OK. I have swapped MI4 with MI5, and my reverse lights still work but my stop lights do not. I have also swapped SH2 with SH6, and my rear fog light still works but my stop lights do not. All other tail lights work too.
Post 658024 by mikealder on 2013-11-04 14:37:08
Put all the relays and shunts back where they should be then get to work with a Digital Voltmeter (DVM) if you don't have one they can be purchased from the likes of Maplins (Code UT30B for under a tenner). Use the meter to look for the 12V feed on the relay socket RMI5 pin 5 of the relay socket with respect to chassis, you should have +12V on that pin all the time. Put the relay back in then move to next step assuming 12V was found on Pin 5 of the relay socket Pull fuse 11D/14 and insert meter probe in to the fuse socket (terminal 1 which is the live pre-fuse side) connect other meter probe to chassis and get a helper to depress the brake pedal, if you get 12V here there is nothing wrong with the CEM/ REM and I would be looking for damage to the Green wire especially around splice 53/667 which you will find in the main wiring loom around the base of the left rear lower light assembly, it should have three green wires in it - Mike
Post 658033 by jdavis on 2013-11-04 17:05:41
Great advice there Mike. Have you checked connection at light unit isn't furred up?
Post 658255 by v70d5 on 2013-11-05 18:21:26
Tks Mike. Socket 5 for MI5 does not give any voltage when the voltmeters negative probe touches the RECM's earth screw, regardless if the ignition is off or on all the way before ignition is initiated. Does this mean that the RECM is defective, and if so, can it be fixed or must it be replaced?
Post 658258 by mikealder on 2013-11-05 18:33:20
Assuming fuse 11D/3 is intact it does appear the REM is defective, this is a very costly item to replace and it you want to work around the issue you can fit another relay external to the REM with a bit of wiring added to get the brake lights working again, the main issue in doing this is the loss of bulb failure detection on the brake lights - Let me know if you want details on how to do this, it isn't difficult and should cost less than £10 in parts - Mike
Post 658277 by v70d5 on 2013-11-05 20:11:53
Hello Mike, Can you please let me know where fuse 11D/3 is located? I am also interested in how to fit a different relay for the4 brake lights that you have mentioned.
Post 658280 by mikealder on 2013-11-05 20:18:40
Image You can work out where 11D/3 is from the above picture, check that before we move on to fitting a new relay, check both sockets the fuse blade fits in to with the meter with respect to chassis and make sure the brake pedal is depressed while looking for a voltage on the meter - Mike
Post 658285 by Jamest5r on 2013-11-05 20:31:03
[QUOTE=mikealder;657728]Double check fuse 3 and 14 in the REM as both of these feed the rear brake lights but have nothing to do with feeding power to the center brake light, if both fuses are OK you will need to pull the right rear trim panel out to get access to the REM, the brake light relay is idented RMI5 - Mike[/QUOTE] [QUOTE=mikealder;658024]Put all the relays and shunts back where they should be then get to work with a Digital Voltmeter (DVM) if you don't have one they can be purchased from the likes of Maplins (Code UT30B for under a tenner). Use the meter to look for the 12V feed on the relay socket RMI5 pin 5 of the relay socket with respect to chassis, you should have +12V on that pin all the time. Put the relay back in then move to next step assuming 12V was found on Pin 5 of the relay socket Pull fuse 11D/14 and insert meter probe in to the fuse socket (terminal 1 which is the live pre-fuse side) connect other meter probe to chassis and get a helper to depress the brake pedal, if you get 12V here there is nothing wrong with the CEM/ REM and I would be looking for damage to the Green wire especially around splice 53/667 which you will find in the main wiring loom around the base of the left rear lower light assembly, it should have three green wires in it - Mike[/QUOTE] [QUOTE=mikealder;658258]Assuming fuse 11D/3 is intact it does appear the REM is defective, this is a very costly item to replace and it you want to work around the issue you can fit another relay external to the REM with a bit of wiring added to get the brake lights working again, the main issue in doing this is the loss of bulb failure detection on the brake lights - Let me know if you want details on how to do this, it isn't difficult and should cost less than £10 in parts - Mike[/QUOTE] [QUOTE=mikealder;658280]Image You can work out where 11D/3 is from the above picture, check that before we move on to fitting a new relay, check both sockets the fuse blade fits in to with the meter with respect to chassis and make sure the brake pedal is depressed while looking for a voltage on the meter - Mike[/QUOTE] Them above got to be the most useful first 4 posts from a member ive ever seen, quality Mr Alder :)
Post 658296 by LiamT4 on 2013-11-05 20:45:56
[QUOTE=Jamest5r;658285]Them above got to be the most useful first 4 posts from a member ive ever seen, quality Mr Alder :)[/QUOTE] Agreed!
Post 658323 by jdavis on 2013-11-05 23:28:06
[QUOTE=LiamT4;658296]Agreed![/QUOTE] Very in depth for first posts. Welcome to VPCUK
Post 658357 by v70d5 on 2013-11-06 11:10:08
Tks again Mike. That confirms that I did check the correct fuse, which is just F3 on my box, and it wasnt reading any voltage when the brake pedal was being pressed. If no voltage is at that fuse nor at pin 5 of the relay, why does the relay still click when the brakes are applied? I unclipped the REM and found that it has three green wires. One goes to F14, one to SH4 and the other to SH5. F14 isnt fitted (my Haynes manual also states that no fuse should be fitted. As you mentioned this fuse, can you please provide more details as to why one should be fitted and what its amps should be?), and those two shunts are not related to the brakes. I can get the inner black part of the REM for around €40 - http://www.ebay.de/itm/Volvo-S60-S80-V70-XC70-Electronic-Module-Steuergerat-8645729-8688153/121207874862?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D134%26meid%3D2508380530706716593%26pid%3D100005%26prg%3D1073%26rk%3D2%26rkt%3D4%26sd%3D111206743625%26 I haven't found the REM's outer grey part yet though. Do you know how to determine if the black or grey part is at fault, or will it be the black part as that has the circuit board inside it? To replace the REM, I see that it will require the removal and fitting of many, many wires, so do you know if there is a special removal tool for them, as I obviously do not want to break any?
Post 658358 by M-R-P on 2013-11-06 11:15:08
[QUOTE=Jamest5r;658285]Them above got to be the most useful first 4 posts from a member ive ever seen, quality Mr Alder :)[/QUOTE] [QUOTE=LiamT4;658296]Agreed![/QUOTE] [QUOTE=jdavis;658323]Very in depth for first posts. Welcome to VPCUK[/QUOTE] Reminds me of Harvey's first post. Pinned down and pretty much fixed an autobox problem with his first post. We should be nice to this lad lol, Welcome aboard Mr. Alder!
Post 658359 by Harvey on 2013-11-06 11:24:23
I don't think you can just if a different one as the software will be wrong,it will need a trip to the dealer.
Post 658365 by jdavis on 2013-11-06 13:06:50
if it's pre facelift i think he may be ok without the dealer visit.
Post 658404 by Harvey on 2013-11-06 17:23:43
What year is the car then.
Post 658410 by mikealder on 2013-11-06 17:58:25
Lets start with the wiring diagram and an explanation as to how the circuit works that I hope will make sense to you, you do indeed need the fuse 11D/14 installed as there is no way for power to pass to the rear outboard brake lights when this is missing - No idea why it is removed from your car and I would far rather trust the Volvo diagram than a generic style diagram in a Haynes book. 11D/14 should be rated at 7,5A. First the diagram which I have colour coded to make it easier to follow in the text below: Image Lets start at top right with the fuse 11B/12 this feeds battery voltage to the brake pedal switch, with the pedal switch depressed the 12V travels through the yellow wire going through connector 54/3LG pin 12 before going to the CEM arriving on pin B4. The CEM then inverts this signal prior to feeding out a discrete signal to the REM on the green and yellow wire routing through connector 54/43 pin 13 which is under the left hand side of the rear seat base. The REM now does two things with the 0V switched signal going in on A4, firstly it provides a +12V output on D4 which is a yellow and red wire this passes through the tailgate connector 54/78 pin 3 where it changes to a yellow wire routing to the center brake light. The other thing the REM does is to energise the brake light relay. All the above is working on the O/Ps car which explains why you can hear the relay clicking when you operate the brake pedal. From this point I will detail what should be happening: +12V is fed through fuse 11D/3 which goes to the brake light relay, when this relay is energised it feeds power out on the yellow wires to the trailer socket 54/51 pin 4 and to the Shunt RSH6 which provides bulb failure detection for the brake light circuit, the yellow wire from the center of RSH6 feeds power to fuse 11D/14 (7,5 Amp rated). The output of fuse 11D/14 is a green wire feeding power to splice 53/667 which is in the main wiring look under the REM, the splice is a small black heat-shrink covered metal barrel containing three green wires. The two green wires then connect to the brake light bulbs on both sides of the car. Try refitting a 7,5A fuse to 11D/14 then see if the brake lights work, if not take the REM off its mounting structure and have a good look at the rear of where the brake light relay is located, check the two yellow wires are still connected to the relay base and not damaged (as in burnt out from connecting the defective trailer) - Hope this helps. Thanks for the welcome chaps, I will start a thread in the correct section about my own V70 when we get this little issue sorted out - Mike
Post 658557 by v70d5 on 2013-11-07 11:16:02
Hello Mike, That was indeed a very good explanation. Adding a 7.5A fuse to F14 in the luggage compartment has rectified this issue. This is embarrassing as I believe that I caused this situation when I was replacing blown fuses. As I didn’t have enough spare fuses, I checked the Haynes manual and as it said that F14 and some others were not used, it must have been one of a few that I used to replace the remaining blown fuses. As it seems that Haynes manual's cannot be trusted, what is the best maintenance book to use for a 2003 V70 LHD?
Post 658621 by mikealder on 2013-11-07 16:51:46
[QUOTE=v70d5;658557]As it seems that Haynes manual's cannot be trusted, what is the best maintenance book to use for a 2003 V70 LHD?[/QUOTE] The Haynes isn't too bad for generic information but you will get better detail and tips for any pending jobs on the car by posting questions on the forum, I would never rely upon a Haynes wiring diagram, the Volvo ones are much better, grab a copy and save it to your PC from [COLOR="#0000CD"]Here[/COLOR] just make sure you pick the correct model and year, the diagrams aren't colour coded like the one I posted earlier but they do contain information about the colour of each wire just remember the abbreviation's used for each colour are in Swedish which can take a bit of getting used to. Glad to hear the car is fixed all the same - Mike
Post 822745 by Tee5alive on 2023-12-13 10:19:51
[QUOTE=mikealder;658621]The Haynes isn't too bad for generic information but you will get better detail and tips for any pending jobs on the car by posting questions on the forum, I would never rely upon a Haynes wiring diagram, the Volvo ones are much better, grab a copy and save it to your PC from [COLOR="#0000CD"]Here[/COLOR] just make sure you pick the correct model and year, the diagrams aren't colour coded like the one I posted earlier but they do contain information about the colour of each wire just remember the abbreviation's used for each colour are in Swedish which can take a bit of getting used to. Glad to hear the car is fixed all the same - Mike[/QUOTE] Hi Mike I know this thread is very old and I thought I knew V70's pretty well as Ive had them for over 20 years! I have raised a question about brake lights. About to go home the other morning after a night shift I started the car but went to move my gear lever from PARK and noticed my brake lights were not working - I know the brake light switch also affects the gear lever locking solenoid, (geartronic gearbox) so the car is immobilized! What I want to also know is WHERE does the locking solenoid take its feed from? The CEM? The electrical diagrams show no solenoid anywhere? I checked the fuse [F9] above the pedals and that was OK. So I took my van home and left the car at work. I fitted a new brake light switch and still nothing. Called the AA at this stage and the guy was next to useless. He spoke little English and I knew more about the car than he did so a wasted 4 hours waiting for them! He plugged in his OBD reader and came out with a load of nonsense that the ABS module was shot ( funny as the brake lights go nowhere NEAR the ABS module according to my wiring diagram) My car is apparently 2004 an 'oddball' fill in model between 2005 and 2007 variants so like a MK 2 1/2! Apparently there is a fuse to the RM15 relay in the cargo area? now on my model its a VERY expensive replacement of the WHOLE REM as its micro relays so nothing replaceable (love why they do this to make us spend more money). I notice you mention how to slave in a new relay Mike? Can you please let me know how to do this? I bought a second hand REM panel believing I could simply swap them out but NO! Harvey says its yet another expensive REPROGRAM job at a Volvo garage! I am a sparks so a bit of wiring and soldering isnt a problem. What if I swap the chips from mine to the replacement REM is that doable? The the software will be correct? Thanks sorry about long question.
