Post 659594 by stribo on 2013-11-11 16:49:46
Went to look at a car today with a view to buy and do up, then sell on. The ETS light was on, and it was hunting on idle. I took it for a run, and to start with it picked up, and boosted fine, after a while it lost power, and made a whooshing sound as if it had popped a boost hose, by the time I got back, it still had no power/ wasn't boosting, but there was no noise, so popped the bonnet and all hoses were where they should have been. Is this all likely to be down to the ETM, or do you think there are other issues.
Post 659596 by M-R-P on 2013-11-11 16:52:40
Nope - won't be ETM, sounds more like a split/loose hose somewhere or even split i/c.
ETM gives erratic idle, random stalls, flatspots in the rev range but won't cause a woosh. or permanent loss of power. Didn't you plug your code reader into it?
Post 659599 by M-R-P on 2013-11-11 16:54:50
D'oh!
Sounds like a boost leak somewhere mate. or possibly a coil pack breaking down.
Post 659606 by stribo on 2013-11-11 16:58:27
A coilpacdk wouldn't cause a noise though would it. It's just strange it stopped, but power didn't pick up.
Post 659613 by M-R-P on 2013-11-11 17:01:47
ME7 - when it detects a boost leak, it'll cut power by limiting boost/fuel/ throttle response (depending on mood)
Coil pack was just something I thought I'd throw in :)
unless the woosh was the noise generated by the car suddenly shutting the throttle due to a coil pack going. (can't remember what mine did when it threw a coil, ran like a 3 legged donkey tho)
Post 659619 by stribo on 2013-11-11 17:04:03
It wasn't misfiring at all just had no boost. Oh well, if it needs a new intercooler that's no biggie, as I'm going to have a spare one.
Post 659621 by stribo on 2013-11-11 17:04:33
[QUOTE=V70 Graham;659616]What car was it Steve ?[/QUOTE]
A Volvo :D
Post 659624 by M-R-P on 2013-11-11 17:05:44
Go for another look mate, check the bottom i/c hose and the short collar between the turbo and top pipe.
Post 659628 by V70 Graham on 2013-11-11 17:07:40
[QUOTE=stribo;659621]A Volvo :D[/QUOTE]
P1200 Amazon.....244.....360.....780.....V90.....am I getting warmer lol
Post 659629 by stribo on 2013-11-11 17:07:46
Won't have time now, a boost leak I can live with, though the drive home might be fun.
Post 659630 by oblark on 2013-11-11 17:07:55
Its either a boost hose split or a sticky waste gate :)
Post 659631 by stribo on 2013-11-11 17:08:23
[QUOTE=V70 Graham;659628]P1200 Amazon.....244.....360.....780.....V90.....am I getting warmer lol[/QUOTE]
Don't know what a P1200 is, but no :P
Post 659637 by M-R-P on 2013-11-11 17:10:46
P1200 - Injector control unit fault :D
Post 659645 by stribo on 2013-11-11 17:14:04
[QUOTE=oblark;659630]Its either a boost hose split or a sticky waste gate :)[/QUOTE]
Both of those are easy fixes looks like it could be worth having then.
Post 659648 by stribo on 2013-11-11 17:16:18
[QUOTE=M-R-P;659637]P1200 - Injector control unit fault :D[/QUOTE]
That's not a type of Volvo. :D
Post 659655 by stribo on 2013-11-11 17:21:16
[QUOTE=oblark;659650]My money is on a C70 :)[/QUOTE]
What do you think I am, a hairdresser. ;)
Post 659661 by oblark on 2013-11-11 17:28:51
Yeah, you own one gay gold one :)
Post 659663 by stribo on 2013-11-11 17:30:38
[QUOTE=oblark;659661]Yeah, you own one gay gold one :)[/QUOTE]
Yeah but that's too quick for a hairdresser. :)
Post 659844 by stribo on 2013-11-11 22:24:41
Are the Magnetti Marelli and Bosch etms interchangeable, i.e. could I remove the Magnetti Marelli that's on there and fit a Bosch one?
Post 659848 by V70 Graham on 2013-11-11 22:32:03
Nope, the bosch unit is just a motor and gears and potentiometer, the car ECU does the processing. The Magneti Marelli has the microprocessor inside. Two completely different units.
Post 659850 by stribo on 2013-11-11 22:35:41
[QUOTE=V70 Graham;659848]Nope, the bosch unit is just a motor and gears and potentiometer, the car ECU does the processing. The Magneti Marelli has the microprocessor inside. Two completely different units.[/QUOTE]
Bloody hell, how do you know that?
Post 659853 by V70 Graham on 2013-11-11 22:38:58
[QUOTE=stribo;659850]Bloody hell, how do you know that?[/QUOTE]
Hahahahaha I'm not just a pretty face....
Post 659854 by LiamT4 on 2013-11-11 22:41:53
Its probably a copy&paste from something that martin has wrote.
Post 659855 by V70 Graham on 2013-11-11 22:48:04
[QUOTE=LiamT4;659854]Its probably a copy&paste from something that martin has wrote.[/QUOTE]
I'm hurt.....
Post 659856 by LiamT4 on 2013-11-11 22:49:11
[QUOTE=V70 Graham;659855]I'm hurt.....[/QUOTE]
That's all I do, remember what other people say lol
Post 659857 by stribo on 2013-11-11 22:49:24
It's true though isn't it?
Post 659858 by V70 Graham on 2013-11-11 22:55:40
[QUOTE=stribo;659857]It's true though isn't it?[/QUOTE]
Hand on heart, I did NOT copy this reply from anything M-R-P has posted.
Post 659859 by M-R-P on 2013-11-11 22:57:35
He's telling the truth.
Thats a deathrider quote lol.
Post 659860 by LiamT4 on 2013-11-11 22:58:14
[QUOTE=V70 Graham;659858]Hand on heart, I did NOT copy this reply from anything M-R-P has posted.[/QUOTE]
Someone else then?
Post 659861 by V70 Graham on 2013-11-11 23:02:02
Everyone seems more interested in how I know rather than in the reply itself lol
Post 659865 by stribo on 2013-11-11 23:13:13
The answer was very useful thanks :D
Post 659869 by M-R-P on 2013-11-11 23:16:43
Having the marelli unit converted to contactless pickups seems to be the way forward with these.
You may not be able to polish a turd but you can sprinkle glitter on it ;)
Post 659877 by Biff on 2013-11-11 23:56:09
C70 vert as they are cheap this time of year? ;)
Sounds like an easy fix to me & boost related with the whooshes.
