My first mod....
Post 53439 by MartinK on 2005-10-29 21:12:58
I felt I needed to improve my C70's handling. It was soft and wallowy; nothing like my Peugeot 406 coupe, which goes round corners like it's on rails. I've heard people say that a strut brace makes a difference, so I decided to get one. I was, however, a little sceptical. After all, the 406 doesn't have one, it just has a sportier suspension setup, and perhaps a stiffer and slightly wider chassis than the saloon 406. Anyhoo, I collected and fitted a strut brace today. What can I say? Wow. What an improvement! The handling has gone from :yikes: to :B_steerin The suspension still feels a little soft, but it now loves the bendy bits. I think I'll be doing more suspension mods before I turn my attention to the engine.
Post 53441 by t5 stealth on 2005-10-29 21:31:48
hi if you change the suspension springs it will make a really big change to it, i got a set of 40mm lowered uprated springs for mine, it lost all the soggy feeling out of the car, it is a different car now, i throw it around like its an old capri, i can give you the number of the place that does them they were just under £100.
Post 53443 by After_Shock on 2005-10-29 21:48:52
Depends on how far you want to go, Springs are a very good option if you dont want to spend to much as the suspension itself isnt bad on them but undoubtedly aimed towards comfort. If you want to go a bit further get a new set of shocks, again a few options available like the springs or if you want to go mad get a set of coilovers, then you can play forever until you get the car exactly the way you want it.
