good morning and hello from essex
Post 664826 by spunkeymonkey on 2013-11-30 09:30:03
Hi iv just signed up to the forum and just wanted to introduce myself, im ollie and im 22 and from essex, iv always loved the t5 engine but until now I havent been able to afford to insure one, I cant remember his forum name but my dad is Paul hassell who ran an autograss special with a 300bhp t5 on full emerald management, so iv spent plenty of time working on them and am now currently saving to get one for myself, im after an 05ish plate ex police v70 t5 as I have a thing for them in white, plus I will know theyve been well looked after, I have however got a couple of questions, do the cloth interiors have heated front seats? Or at least the wiring for them? As I would like to change it to black leather with the heated seats and I want to fit the cruise control aswell etc so just working out how much of a job that will be, thanks, ollie
Post 664827 by T5frankie on 2013-11-30 09:39:14
Post 664828 by T5RatherAmusin on 2013-11-30 09:42:42
welcome! you can change to heatedseats. ive just fitted a complete R interior in mine.... to get the heated seats to work tho, youll need the software setup from volvo and a button...
Post 664829 by spunkeymonkey on 2013-11-30 09:49:34
Yeah thats fine to get that done all I wanted to know was if the wiring is there for it cos changing the wiringloom is a mission haha
Post 664831 by jamesy12345 on 2013-11-30 10:01:18
Morning, nice user name :welcome:
Post 664833 by Santa on 2013-11-30 10:28:02
Post 664834 by Martin-t5r on 2013-11-30 10:32:23
Welcome, been over to your place before to pick some roof trims up off a shell that you had taken engine from for auto grass car
Post 664836 by spunkeymonkey on 2013-11-30 10:44:15
Haha fair enough, yeah my dad used to break a few 850s for spares for the racing, my dads not racing now but my brother has one the same class but with two suzuki gsxr1000s in the back side by side which is a bit of an animal
Post 664837 by andyb1375 on 2013-11-30 10:55:35
Post 664839 by T5RatherAmusin on 2013-11-30 11:02:01
[QUOTE=spunkeymonkey;664829]Yeah thats fine to get that done all I wanted to know was if the wiring is there for it cos changing the wiringloom is a mission haha[/QUOTE] ye wirings all there. just as said button and software from volvo...thinks its about 100 bob to do
Post 664841 by spunkeymonkey on 2013-11-30 12:28:20
Thats notnto bad then, is it the same with cruise control? Im not sure if the police ones had it but is that just a case of the switches and software? If it is then I will get all the gear together and fitted and just do the software all in one go :)
Post 664842 by T5RatherAmusin on 2013-11-30 12:37:15
not many xplods had the cruise control. but just a matter of the switches and software agin. you can do this on vida
Post 664844 by spunkeymonkey on 2013-11-30 12:52:00
Ok then thats fine, that sounds easy enough to do so thats alright :)
Post 664845 by BIG G on 2013-11-30 13:08:26
Hello n welcome
Post 664859 by Kingsford G on 2013-11-30 16:32:54
Hi and welcome.I have the car you want if the price is right(I`m having the frankie bug lately)
Post 664860 by stribo on 2013-11-30 16:45:45
Post 664864 by V70 Graham on 2013-11-30 16:54:59
Post 664868 by mikealder on 2013-11-30 17:08:10
This covers what I did recently to add seat heaters to an S60 with leather seats but no seat heaters fitted as they can be quite cold in the winter mornings, this little lot shows what can be done to add heater pads to both parts of the front seats, not a difficult job but does take a few hours to get it right, shouldn't be any different on a V70: This write up assumes you know how to remove the front seats and the necessary precautions when messing around with front seats that contain airbags. In short you need to remove the four bolts that hold the seat to the chassis before disconnecting the cars battery only then can you disconnect the seats electrical connector(s) to remove the seat from the car. Firstly you need to remove all the hog rings securing the bottom of the leather cover to the base of the seat, best removed using wire cutters by twisting the ring to undo it before threading it out of the seat material: Image Underneath the seat at the rear of the base are a few more hog rings attaching the leather cover to the seat springs, again remove the rings to release the cover Image With all the hog rings removed from around the base the sides should pull up over the base foam insert: Image Carefully lift the leather cover up to expose the first hog ring connecting the cover to the foam base then remove it, take care not to apply too much vertical force though as you don't want to pull the metal rod out of the foam base Image Continue removing hog rings from both sides of the base until you get to the first set of rings running across the base of the seat, remove the hog rings Image Then continue working further rearwards to get to the next set of rings running across the seat, remove these rings Image Eventually you will have the leather base cover removed although we left the rear most hog rings in place as we could work around them but you should end up with the seat base looking something like this: Image Place the heater mat on to the foam base and push the electrical wires through to the rear of the seat, push the seat heater down in to the channel where the hog rings need to go running side to side and mark the area with a felt tip pen: Image Working further forwards again push the heater mat in to the next channel in the foam base running side to side and mark the location with a felt tip pen: Image Towards the rear of the heater mat is a temperature switch, this needs to sit in to a small recess in the foam otherwise you will feel it when sitting in the seat, simply tear out a small chuck of foam from the base to accommodate the temp sensor: Image The location of the seat temperature sensor although it is difficult to see from the picture, it is very easy to locate by feel: Image Cut the heater mat where marked up but don't cut the outer 1" strips as these run the power forwards to the rest of the seat heater mat, the slots are required to re-secure the seat cover later on: Image The lower side of the heater mat is covered with self-adhesive strips, remove the backing paper and secure the mat in to position making sure that at the two channels running side to side you push the may in to the groove to seat it fully: Image Finally put a length of adhesive tape over the leading edge of the heater mat to secure it to the foam base: Image Here we decided to cheat using more modern kit than the hog rings removed earlier as getting new hog rings in place was nigh on impossible due to the restricted access, firstly tywraps were fitted to the leather seat cover: Image To be continued:
Post 664869 by mikealder on 2013-11-30 17:09:13
Part two: The tywraps were then pushed under the metal rod in the foam base and tensioned: Image Pushing the leather cover down in to the gap allows the tywrap to be fully tightened up: Image Finally cut the tail off the tywrap then rotate the tywrap so the head of it is sat under the wire in the foam base (this way you won't feel it when you are sat on the seat, continue to add and secure the tywraps until all the leather cover attachments are in place and secured: Image The sides can then be secured using hog ring pliers as the access is somewhat easier: Image New hog rings securing the sides in place: Image Applying more new hog rings to secure the front of the leather seat cover to the metal seat frame: Image That's the first half back together, next up is the seat back: Image Four hog rings secure the front of the seat back to the front at the lower rear edge of the seat: Image Remove the rings and the seat back cover starts to release: Image The side flaps simply stretch over the plastic side parts of the seat: Image Guess what is stopping the seat back cover from coming off, yes more hog rings, again much in the same way as the base came to bits these rings have to be removed one by one without exerting too much pressure on the rods that are part of the foam as you don't want the rod to pull out: Image Work methodically from the base of the seat removing the rings from the vertical channels then once exposed remove the rings from the horizontal channels: Image We stopped at the second horizontal channel for the hog rings as the seat heater mat was only long enough to get this far up the seat (no point making even more work): Image Pop the heater mat in to position and mark out the location of the horizontal channel with a felt tip pen: Image Cut through the heater mat avoiding cutting the outer 1" section then secure the mat down to the foam using the self adhesive strips: Image To be continued:
Post 664870 by mikealder on 2013-11-30 17:09:45
Again more tywraps applied in the same way as we did the work on the base: Image Finally you get to the rear opening of the seat which needs clipping together: Image More hog rings and that is the seat upholstery work completed, the wiring and control relay was clipped up under the seat and it was time to pop the seat back in to the car: Image Passenger seat two stage heat control switch: Image Drivers side two stage heat control switch: Image Green denotes stage one heat: Image Red denotes stage two heat: Image For the power to supply the seat heaters we used the Volvo fitted seat heater supply lines which is a Blue wire with red stipe (+12) in pin one of the seat connector and the Black wore in pin 3 of the seat connector is 0V (-) - The 15A fuses were already fitted which was an added bonus - All four seat heater pads are now working, total time spent was between 5 and 6 hours to complete both front seats, better still it avoids the Volvo main dealer charges for "Software" which you cannot do DIY style, the switches for the factory fit seat heaters reside in the climatic control panel and it isn't possible to use the output from these switches if you add them to the panel without the software - Mike
Post 664931 by merc85 on 2013-11-30 20:47:34
Welcome mate, another one from essex ;)
Post 664964 by Jim S70R on 2013-11-30 21:46:23
Welcome to the club
Post 664988 by theflyingbrick on 2013-11-30 22:52:21
welcome along :)
Post 664991 by Nealevo on 2013-11-30 23:08:30
Welcome, have fun.
Post 664994 by Harvey on 2013-11-30 23:33:56
Hi welcome
Post 665010 by bjpub on 2013-12-01 08:37:25
Welcome :funkybana
Post 665013 by WOODY T5 on 2013-12-01 08:44:36
Welcome to vpc
Post 665057 by Wobbly Dave on 2013-12-01 13:56:14
Welcome spunkey son of Paul. I hope your Dad's doing well. The firm that is doing my race engine are also into Autograss. Given the array of available cars - I'd be tempted to have a look at the C70. They are cheap as chips and for a young lad like yourself I think would be a much better choice than ex-plod.
