V70 Diesel Strut Brace
Post 666682 by Henk on 2013-12-06 20:57:54
Installed the standard Volvo strut brace on my MK1 V70 TDi today. becuase it didn't sound that hard. The issues are the bracket holding the main fuse box on the right hand top mount, and the fuel filter on the left Thought a how-to run through might be helpful Removed both, and put the brace on Image Fuse box was pretty close to fitting ontop of the, but the box fouled the brace. Cut the bracket and welded it back slightly forward Image when assembled it's pretty close but it goes together Image The fuel filter took a bit more, i decided to just modify the bracket and mount it to the brace itself. bit of a quick-fix really but it'll be fine cut the top off the bracket, plasma cut myself a new top piece out of 3mm sheet, cleaned it up and welded to the bottom bracket I cocked up a bit here, the top fuel hose fouled the back when it went together, had to undo the banjo fitting and turn it around a bit to clear Image Image Job done Image Took about 2 hours to do. Hope this can be of use to others :)
