Clunk 'n' grind!!!
Post 53780 by jeleebaby on 2005-10-31 17:09:29
On full lock (either way) have a grinding and knocking sound from the front, can't pinpoint it. Anyone else had this problem? Any ideas?
Post 53784 by Vikingxl on 2005-10-31 17:16:51
Turn the radio up
Post 53786 by jeleebaby on 2005-10-31 17:18:52
Thanks Rich, very helpful, not sure why I didn't think of that!
Post 53787 by Vikingxl on 2005-10-31 17:19:06
[QUOTE=vikingt5]Turn the radio up[/QUOTE] Sorry couldnt help it!
Post 53797 by Engineer on 2005-10-31 18:05:20
Always difficult to diagnose other peeps interpretation of noises, but outer CV joints comes to mind along with power steering pump which is on full load at full lock had this a few times, try testing with bonnet up.
Post 53805 by splatt on 2005-10-31 18:48:18
850? it was a common prob if so, to do with the angles of the cv joints (I have a 850 manufacturers training manual which talks about this...)
Post 53807 by jeleebaby on 2005-10-31 19:03:42
[QUOTE=splatt]850? it was a common prob if so, to do with the angles of the cv joints (I have a 850 manufacturers training manual which talks about this...)[/QUOTE] V70 1997
Post 53810 by pault5 on 2005-10-31 19:11:18
could be the steering lock stops, they should be greased.
Post 53812 by Kent Canary on 2005-10-31 19:18:53
Try track rod ends
Post 53819 by t5 stealth on 2005-10-31 19:33:57
have you changed wheels or tyres, is the noise since this or any other work carried out on the car, if so then it mite be tyres touching inner wing liners, ,,,,,,,,maybe,,,,,,,,,
Post 53849 by Unknown on 2005-10-31 22:21:47
What tyre sizes you running ?
Post 53858 by splatt on 2005-10-31 22:40:57
[QUOTE=jeleebaby]V70 1997[/QUOTE] Reckon its the CV joints still as theres not a lot of difference in reality between early 70's and late 850's. CV joints are prone to lots of little crunchy noises even when relatively new. Someone will have to hear it to get it right but CV's most likely. if it is on full lock only then dont worry too mutch about it.
Post 53927 by swordy21 on 2005-11-01 12:52:52
Does sound like CV joints to me as well. Is it only on full lock, or can you almost feel a rumble up from the floor of the car as well? On the otherhand I had a knocking noise on mine on full lock, turned out to be the suspension top mounts and drop links. Worth getting Hamish to have a look?
