Post 672132 by bongodave on 2013-12-21 23:55:33
As much as I love my old V70r '98, I've swapped the gear knob and gaiters as they were showing the age far more than rest of car.
I was wondering if the later V70 steering wheels fitted. The main issue being airbag connectors as not fussed about H,U controls.
Anyone got any ideas?
Post 672137 by Tomcat on 2013-12-22 00:06:48
I've seen one fitted but I dont know how easy it is.
Post 672138 by Tomcat on 2013-12-22 00:10:40
Added some pics, this is in a ph1 V70.
Post 672141 by bongodave on 2013-12-22 00:14:43
[QUOTE=Tomcat;672138]Added some pics, this is in a ph1 V70.[/QUOTE]
Cheers for that. Looks pretty good!
This is the wheel I was thinking as cheap n cheerful. Guess it depends on the airbag connecting up without codes.
[ATTACH=CONFIG]23270[/ATTACH]
Post 672158 by M-R-P on 2013-12-22 00:49:38
The P2 airbag connections are doubled - up. One low-speed and one high-speed.
Use the orange high-speed connection and ignore the other when fitting it to the P1 and you'll be fine.
The stereo controls aren't that hard to sort if you go for an aftermarket HU.
Post 672159 by bongodave on 2013-12-22 00:52:05
[QUOTE=M-R-P;672158]The P2 airbag connections are doubled - up. One low-speed and one high-speed.
The stereo controls aren't that hard to sort if you go for an aftermarket HU.[/QUOTE]
Top man! Thanks for that. V.useful.
Will get the wheel then as only £35.
Post 672213 by Biff on 2013-12-22 08:25:59
As said pal they do work. He who must not be named has one fitted to his laser blue v70r off an s60 which is what I plan to do when I rip out my cream interior. :)
Post 672235 by Harvey on 2013-12-22 09:57:24
I do know V70graham does have a thing for the wooden steering wheels.
Post 672246 by V70 Graham on 2013-12-22 10:20:44
[QUOTE=Harvey;672235]I do know V70graham does have a thing for the wooden steering wheels.[/QUOTE]
Yeah, my THING is I can't find one lol
Post 808485 by Jc2320 on 2017-01-04 14:18:48
Hi. Sorry to come back on this. I am trying to do the swap in a c70 2001 with a v70 2002 steering. The p2 has 2 connectors, 1 pink and 1 green... but no.orange. which one do i have to use? Thanks[ATTACH=CONFIG]31309[/ATTACH][ATTACH=CONFIG]31310[/ATTACH]
Post 808504 by Ayrshore on 2017-01-06 01:03:01
Just stick a 2 ohm resistor in it and don't crash. :P
Post 808505 by Ettienne on 2017-01-06 07:52:06
Ones a 30% fill the other 70% fill, connect up the 70% and job done not airbag light but less fill in an accident.
I fitted a couple to 850s in the past.
Post 808515 by Harvey on 2017-01-06 12:36:22
[QUOTE=Ayrshore;808504]Just stick a 2 ohm resistor in it and don't crash. :P[/QUOTE]
