which mod should I get next
Post 675236 by expolicev70t5 on 2013-12-29 08:55:11
I am now torn, do I get the MTE remap next, or the nice 19" wheels I've seen on eBay, need to decide performance or looks, so hard to choose
Post 675240 by V70 Graham on 2013-12-29 09:12:52
If you get the remap you might not find the wheels again, if you get the wheels you can always get a remap later.
Post 675241 by stephenevans99 on 2013-12-29 09:14:35
My question would be 'How are your current tyres?', if they're only half worn - then I'd say go for the MTE remap. If they're knackered then the new alloy package. HTH Steve
Post 675245 by silverhorse on 2013-12-29 09:37:12
I agree with Stephen. Just out of interest, will the 19's totally ruin the ride? I know 17's to 18's can make a fair bit of difference
Post 675246 by stribo on 2013-12-29 09:37:15
I have only one word for you, POWER!!!!
Post 675248 by M-R-P on 2013-12-29 09:59:12
if you have that kind of money kicking about, I'd start upgrading suspension and brakes. no point having all that power if you're gonna end up on your roof in a field.
Post 675251 by koperbart on 2013-12-29 10:09:38
[QUOTE=M-R-P;675248]if you have that kind of money kicking about, I'd start upgrading suspension and brakes. no point having all that power if you're gonna end up on your roof in a field.[/QUOTE] I agree with You. I stop thinking about exhaust, remap ect. On first order is for me good set of alloys/tyres, suspension and brakes.
Post 675253 by stribo on 2013-12-29 10:15:10
[QUOTE=M-R-P;675248]if you have that kind of money kicking about, I'd start upgrading suspension and brakes. no point having all that power if you're gonna end up on your roof in a field.[/QUOTE] Brakes are for wimps. ;)
Post 675257 by M-R-P on 2013-12-29 10:38:49
[QUOTE=stribo;675253]Brakes are for wimps. ;)[/QUOTE] is that why you hammered yours so hard you melted the pads? :)
Post 675258 by Biff on 2013-12-29 10:39:48
I was always told good handling & stopping can make all the difference & can be the same as +50bhp. Top gear proved me wrong with that modified Renault thing they built. Personally I would leave the map till last & would only upgrade the wheels/tyres with a decent size & tyre brand. Hope this helps. ;)
Post 675282 by stribo on 2013-12-29 11:19:23
[QUOTE=M-R-P;675257]is that why you hammered yours so hard you melted the pads? :)[/QUOTE] They're crap pads, didn't use brakes much after the pads had broken into chunks and stuck to the discs. ;)
Post 675293 by expolicev70t5 on 2013-12-29 11:41:38
[QUOTE=V70 Graham;675240]If you get the remap you might not find the wheels again, if you get the wheels you can always get a remap later.[/QUOTE] I've been watching the wheels for three or four months now, they are new from an alloy wheel supplier on eBay and they keep relisting them car would look the dogs on them, then I keep thinking about Dons quote of 395 for a stage 3 MTE remap giving the extra ooumph for overtaking. As far as current tyres go I have winters on at minute, but when I come to change them back I would need a couple of new tyres for front. I would only put a decent make of tyres on, I generally run Goodyear f1s for summer
Post 675294 by expolicev70t5 on 2013-12-29 11:44:46
[QUOTE=M-R-P;675248]if you have that kind of money kicking about, I'd start upgrading suspension and brakes. no point having all that power if you're gonna end up on your roof in a field.[/QUOTE] Brakes are ok as being xplod p2.5 it has the big discs and XC90 calipers, admittedly it does want lowering
Post 675297 by M-R-P on 2013-12-29 11:52:55
[QUOTE=expolicev70t5;675294]Brakes are ok as being xplod p2.5 it has the big discs and XC90 calipers, admittedly it does want lowering[/QUOTE] upgraded bushes (powerflex or meyle hd etc) your ARBs should be fine, shocks (I have boge automatic at 190 quid a pair) braided brake lines (mainly for bling) stiffened strut brace, you could go up a brake size too if you felt the urge, the 336mm setup is rather effective ;) dot 5.1 fluid is a must too.
Post 675298 by M-R-P on 2013-12-29 11:53:41
oh, avoid apex springs if you value your fillings lol.
Post 675325 by expolicev70t5 on 2013-12-29 13:06:22
[QUOTE=M-R-P;675298]oh, avoid apex springs if you value your fillings lol.[/QUOTE] Will bear this in mind when I get some lowering springs
Post 675328 by LiamT4 on 2013-12-29 13:10:04
If your getting 19's then you'll lose your fillings anyway lol
Post 675330 by expolicev70t5 on 2013-12-29 13:16:36
Yes but it will look the dogs danglys
Post 675335 by T5RatherAmusin on 2013-12-29 13:40:47
on stilts the 19s will look abit naff gotta slam it on its arse to work ;)
Post 675371 by graemewelch on 2013-12-29 14:38:59
get eibach springs. they give a nice ride. id be going for the remap if i was you
