It's finally on. :D
Post 676935 by stribo on 2014-01-03 13:14:33
Over the past day and a half I've finally fitted Rachel's Christmas present, the downpipe with sports cat. Yes, it's taken a day and a half, because it's a hateful job that I would never undertake again. I was going to do a how-to, but my how-to is now take it to a garage to get it fitted. Nothing's particularly easily accessible, owing to the proximity of the propshaft and the angle gearbox. Getting the new one in is the hardest part, as the 90 bend coming from the flange which connects to the turbo isn't as tight as the standard downpipe, so the pipe sits in a slightly different position, it also means the lambda has to be fitted once the pipe is in place as it won't clear the steering column, and as it's tucked under the servo, this is awkward. The pipe itself looks good now it's in place, and once I've sorted a slight blow between the exhaust and downpipe should sound good too. I only got the chance to take 1 photo so far, as I finished it in the pouring rain, so decided to wait until later to take some pics, and do a vid of the sound. Standard and GWE. Image
Post 676937 by M-R-P on 2014-01-03 13:19:30
bout bloody time. a new gasket is only about 2 quid from my local zorst place, I donated mine to chavboy's R exhaust install.
Post 676939 by stribo on 2014-01-03 13:24:28
[QUOTE=M-R-P;676937]bout bloody time. a new gasket is only about 2 quid from my local zorst place, I donated mine to chavboy's R exhaust install.[/QUOTE] Just going to whack some silicon sealant around the existing gasket. If I'd have known how hard it was going to be, it would still be in the conservatory. ;)
Post 676940 by M-R-P on 2014-01-03 13:26:44
[QUOTE=stribo;676939]Just going to whack some silicon sealant around the existing gasket. If I'd have known how hard it was going to be, it would still be in the conservatory. ;)[/QUOTE] I'll be sticking a new downpipe on mine soon. I'll let you know how much easier it is ;)
Post 676942 by stribo on 2014-01-03 13:28:22
[QUOTE=M-R-P;676940]I'll be sticking a new downpipe on mine soon. I'll let you know how much easier it is ;)[/QUOTE] It'll be a piece of cake on the FWD, it's the bloody angle gearbox that's the biggest obstacle, I even considered taking it off at one point.
Post 676946 by V70 Graham on 2014-01-03 13:33:34
Well done mate, glad to see it's finally been fitted.
Post 676947 by M-R-P on 2014-01-03 13:35:53
[QUOTE=stribo;676942]It'll be a piece of cake on the FWD, it's the bloody angle gearbox that's the biggest obstacle, I even considered taking it off at one point.[/QUOTE] I know ;) :D [QUOTE=V70 Graham;676946]Well done mate, glad to see it's finally been fitted.[/QUOTE] I was expecting you to be giving this thread a wide birth mate lol.
Post 676949 by stribo on 2014-01-03 13:37:13
[QUOTE=M-R-P;676947]I know ;) :D I was expecting you to be giving this thread a wide birth mate lol.[/QUOTE] Even with the slight blow, it doesn't drone. :D
Post 676950 by M-R-P on 2014-01-03 13:38:33
[QUOTE=stribo;676949]Even with the slight blow, it doesn't drone. :D[/QUOTE] Any lights come on yet? (which of will get the snotty text message first? place your bets...)
Post 676951 by stribo on 2014-01-03 13:40:18
No, no warning lights apart from the traction control light gave me a brief flash when I gave it the beans. I'm betting you. ;)
Post 676952 by M-R-P on 2014-01-03 13:42:06
Looking at the above pic, I recon you were due a new downpipe... or did you shag the old flexi trying to get it out?
Post 676958 by stribo on 2014-01-03 13:51:07
It was a lot more flexible than the new one, so it could well have been on it's way out, though it has corrugated pipe under the braided wire, so not sure if it would leak or not. I may have snagged it on the way out, it was a case of brute force and ignorance to remove it.
Post 676959 by Dangerous Dave on 2014-01-03 13:53:29
[QUOTE=stribo;676942]It'll be a piece of cake on the FWD, it's the bloody angle gearbox that's the biggest obstacle, I even considered taking it off at one point.[/QUOTE] You're lucky, on the older AWD's the downpipe does a 180 under the turbo over the top of the propshaft. So I think (as I've never done it) the propshaft has to be undone first :(
Post 676960 by stribo on 2014-01-03 13:59:20
[QUOTE=Dangerous Dave;676959]You're lucky, on the older AWD's the downpipe does a 180 under the turbo over the top of the propshaft. So I think (as I've never done it) the propshaft has to be undone first :([/QUOTE] That sounds like even more fun, just glad I'll never have to do it again. :D
Post 676962 by expolicev70t5 on 2014-01-03 14:10:03
Will be interested to see how it sounds, very pleased with mine from GWE :smile:
Post 676966 by graemewelch on 2014-01-03 14:24:12
ill take note and make the leg length shorter on the top part of the cat to avoid trouble with lambda sensors in the future. glad to see its finaly fitted though [QUOTE=stribo;676942]It'll be a piece of cake on the FWD, it's the bloody angle gearbox that's the biggest obstacle, I even considered taking it off at one point.[/QUOTE] it is a piece of cake. i can have mine off in 25 mins.
Post 676968 by Harvey on 2014-01-03 14:29:40
Nice to see its on at last,I think I will leave my one alone for now ,as you say its a nice easy job,
Post 676969 by merc85 on 2014-01-03 14:32:16
[QUOTE=stribo;676939]Just going to whack some silicon sealant around the existing gasket. If I'd have known how hard it was going to be, it would still be in the conservatory. ;)[/QUOTE] Looks awesome, i take it you mean silicone sealent after the cat?
Post 676970 by stribo on 2014-01-03 14:33:33
[QUOTE=Harvey;676968]Nice to see its on at last,I think I will leave my one alone for now ,as you say its a nice easy job,[/QUOTE] Take it to an exhaust place and get them to fit it, probably a bit easier if it's up on a ramp.
Post 676972 by stribo on 2014-01-03 14:34:04
[QUOTE=merc85;676969]Looks awesome, i take it you mean silicone sealent after the cat?[/QUOTE] Yeah, where the downpipe meets the exhaust.
Post 676973 by Harvey on 2014-01-03 14:38:10
[QUOTE=stribo;676939]Just going to whack some silicon sealant around the existing gasket. If I'd have known how hard it was going to be, it would still be in the conservatory. ;)[/QUOTE] The gasket from volvo is about £8 as I just fitted a new one to mine when I fitted my cat back system
Post 676978 by graemewelch on 2014-01-03 14:42:24
http://www.ebay.co.uk/itm/Supra-Exhaust-Gasket-2-Bolt-Hole-Gaskets-3-76-2mm-/290581125248?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a7fc1880
Post 676980 by stribo on 2014-01-03 14:46:46
[QUOTE=Harvey;676973]The gasket from volvo is about £8 as I just fitted a new one to mine when I fitted my cat back system[/QUOTE] [QUOTE=graemewelch;676978]http://www.ebay.co.uk/itm/Supra-Exhaust-Gasket-2-Bolt-Hole-Gaskets-3-76-2mm-/290581125248?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a7fc1880[/QUOTE] But I have loads of silicon sealant. ;)
Post 676987 by M-R-P on 2014-01-03 15:13:32
[QUOTE=stribo;676980]But I have loads of silicon sealant. ;)[/QUOTE] bloody jobsworth.
Post 676990 by stribo on 2014-01-03 15:17:48
[QUOTE=M-R-P;676987]bloody jobsworth.[/QUOTE] More like cheapskate. ;)
Post 676998 by graemewelch on 2014-01-03 15:47:41
[QUOTE=stribo;676990]More like cheapskate. ;)[/QUOTE] couldnt of put it better myself.
Post 677008 by Biff on 2014-01-03 16:34:41
I can vouch for the down pipe on a ph1 awd. Horrible job & I'll need to do it again at some point. I made some noises doing that job.
Post 677012 by rikcougar on 2014-01-03 16:44:28
Sounds like a pig of a job Steve Glad it`s all over :B_thumb: Silicon is for bathrooms mate, not high performance vehicles
Post 677054 by stribo on 2014-01-03 18:53:03
[QUOTE=graemewelch;676998]couldnt of put it better myself.[/QUOTE] That's rich coming from someone who can't be bothered to buy drill bits. :P
Post 677055 by deathrider311271 on 2014-01-03 18:58:06
looks like a nice piece of work
Post 677056 by graemewelch on 2014-01-03 18:59:38
[QUOTE=stribo;677054]That's rich coming from someone who can't be bothered to buy drill bits. :P[/QUOTE] got loads of drill bits. the bit the drill bit went into is another storey. that blew up. got two now. bought one just befor xmas then got another one for xmas
Post 677070 by stribo on 2014-01-03 19:19:42
[QUOTE=deathrider311271;677055]looks like a nice piece of work[/QUOTE] It's a lovely bit of kit mate, just a ballache to fit on a AWD car. Quick update, Rachel's taken the car to work, and I got a text from her saying it feels quicker/ more eager, so she's a happy bunny. :D
