Rewire 850 Series Headlights
Post 680305 by Mr Sheen on 2014-01-14 18:22:29
For a few months I've been having problems with my N/S headlight dip beam. It's been flickering, sometimes not coming on for a few minutes after headlights turned on. I went to replace the bulb and found the insulation on the wiring inside the headlights had split with age and heat:- Image So my only option was to rewire them, well as I'm a bit of a dab hand with the soldering iron :) First step, remove the trim from below the headlight, then unclip the indicator. Image Unclip the connectors for the headlight leveling motor and the connector for the headlight power, then the three 10mm bolts holding the headlight too the car. Image Remove the headlight from the car and put it on the workbench. Use a large flat head screwdriver to release the clips holding the glass in place. I cleaned the inside of the glass with Auto Glym Glass Cleaner as it was kinda filthy looking. Image Pull the glass free from the headlight. The tricky part is releasing the reflector from the body of the headlight, the leveling motor is a twist to release, then unclip the motors ball joint on the rear of the reflector. The reflector is held in place by two other clips, these are released with a screwdriver and a bit of brute force. Image DO NOT be tempted to clean the reflector as the material is very thin and easily damaged by cleaning agents. You'll now be left with this..... Image Pull the 4 wires off the bulbs. This will release the reflector, place it safely to one side. I decided to remove the wiring loom from the headlight to make it easier to work on. The power connector is held in by clips, use a screwdriver to relase them and remove the loom through the rear of the headlight body. I cut the wires close to the connector body, and soldered on new lengths of wires. Use heatshrink sleeving to cover the solder joints. Image New blade terminals will be needed so the new wires can be connected to the bulbs and the reflector body. Refitting as the Hayne's Manuals aways say is the reverse of removal. Once the headlight is refitted to the car, the aim of the headlight will need to be checked.
Post 680319 by Jimmie on 2014-01-14 19:15:14
Gregg it's nice to see the old girl is still with you. Have any updated photos if you have post them up.
Post 680342 by Mr Sheen on 2014-01-14 19:59:24
Cheers Jimmy, she's still going strong. Will get some pics up at some point.
