Post 683215 by oblark on 2014-01-23 19:33:44
After reading a few threads on VS about fitting N/A cams. http://volvospeed.com/vs_forum/topic/153406-na-cams-in-my-turbo-850/ http://volvospeed.com/vs_forum/topic/127747-upgrade-na-cams-only-intake-cam-or-upgrade-both-intex-on-my-850-t5-r/ I thought I would show how I have timed my N/A cams. First I locked the cams in position and checked the front timing marks. Then a put my digital angle gauge on flat piece of plate which fitted in the slot in the end of the exhaust cam. The angle gauge was set to zero. The 3 bolts on the front of the cam pulley were slackered off and the cam moved anti-clock by 2 degrees. Then tighten the 3 bolts on the cam pulley, as you can see on the pulley it`s only small movement. As for the inlet cam I did the same but moved the cam 2 degrees clockwise. Then turned the engine over slowly to make sure it turned freely :)
