Post 684803 by mhill53 on 2014-01-27 17:04:09
Good evening all,
My 850r has thrown up the fuel and ignition electrical system light for some reason, ran the old girl empty the other day and she cut out just as I got home!!
Anyway ever since that the lights on. I've tried my dads code reader which is a memo scanner U480 but it just reads "linking error"?
Any ideas?
Car runs fine just annoys me having the light on.
Cheers
Post 684806 by oblark on 2014-01-27 17:10:19
Either give it 50-60 miles to see if it clears it's self if not take to local independent volvo garage to get the codes read/cleared.
Post 684807 by T5frankie on 2014-01-27 17:16:24
obd2 doesnt work in 850's mate
Post 684812 by cherry1809 on 2014-01-27 17:32:31
Thought the later 850's were obd2?
Post 684820 by merc85 on 2014-01-27 17:50:43
snap on launch will read and clear the codes, 95- 850's are primitive obd2, socket is under the centre consul. But as said before only certain obd 2 scanner/reader can connect via it.
-95 the code reader is built in, onto the front of the ecu Box housing, this has its own fly lead were you can read the dtc's and clear them.
Post 684869 by JUDGENINJA on 2014-01-27 19:42:25
Later 850s had an OBD2 compliance, but someone forgot to tell the diagnostic tool manufacturers. My 855 was one of the Last of the production line and standard code readers didn't work.
Post 688666 by mhill53 on 2014-02-10 21:00:01
Ok Chaps, i made myself a code reader andit is diplaying the following 2 faults;
414
121
Looking online it appears this points towards a MAF failing? do you guys agree?
Post 689599 by Darkstar-SFX on 2014-02-15 14:26:24
I'm glad I saw this thread, as I was on the verge of buying an OBD2 reader. The couple I was looking at are Autel Autoscan 319 and 419, which state they scan *all* OBD2. I also found one that said it was specifically for Volvos, but didn't like the look of it.... Now I'm not sure what to go for?
Car is 96 850R with OBD2 socket under a panel next to the cig lighter. When I had my 97 V70 MOT'd by Cambridge Council, they had to take it to Marshal's, as their reader wouldn't work - which doesn't bode well (V70 had OBD2 socket in centre arm rest cubby hole)
Post 689613 by stribo on 2014-02-15 15:08:47
The one Oblarks linked definitely works, as I've got one, and used it on his car.
Post 689623 by cherry1809 on 2014-02-15 15:56:21
[QUOTE=stribo;689613]The one Oblarks linked definitely works, as I've got one, and used it on his car.[/QUOTE]
Can have mine if you like, it won't clear the codes on my D5 and I now use a mate at work instead.
Post 689638 by Redbrick on 2014-02-15 17:33:15
You can't beat the wire and LED bulb trick for cheapness!!!
You can clear codes as well, I just can't remember how at the moment. I'll have a root around...
http://www.volvoforums.org.uk/showthread.php?t=83897
