Post 685716 by LeeT5 on 2014-01-31 01:21:49
Hello everybody!
Can anyone tell me if this kit http://www.partsforvolvosonline.com/product_info.php?cPath=705&products_id=7990 is any good? Anyone use it? Any advantages/disadvantages over the IMiv 'classic' kit, that I currently use?
Also, does it charge the iPhone when plugged in?
PFV, maybe you could help me on this one??
Post 685735 by Harvey on 2014-01-31 09:14:46
Site is down at the moment.
Post 685737 by LeeT5 on 2014-01-31 09:26:37
Up and running. The link works.
Post 685751 by stephenevans99 on 2014-01-31 10:20:27
[QUOTE=Harvey;685735]Site is down at the moment.[/QUOTE]
+1 Says it's down for maintenance here too
Post 685761 by V70 Graham on 2014-01-31 11:48:47
Seems to be working fine....the site that is, haven't tried the unit.
Post 685766 by partsforvolvos.com on 2014-01-31 12:19:45
I have sold a few of these and the feedback has been positive.
regarding charging, it depends on your I device, as the later ones might require an apple adapter as for some unknown reason apple changed the position of the charging pin within the plug.
somebody will probably correct me, but an ' apple lightning' adapter rings a bell.
Post 685767 by LeeT5 on 2014-01-31 12:34:43
[QUOTE=partsforvolvos.com;685766]I have sold a few of these and the feedback has been positive.
somebody will probably correct me, but an ' apple lightning' adapter rings a bell.[/QUOTE]
Lightning adapter is for iPhone 5>
I have an iPhone 4S which uses a normal ipod interface. So will it charge? £70 is a lot to spend and rip yer dash out and plug it all in to find it doesn't charge! Then have to return it.
Post 685769 by partsforvolvos.com on 2014-01-31 12:40:56
I am told by the supplier it will charge a 4s straightaway.
I know less than nothing about apple stuff as I purposely avoid it !
