Post 685996 by inde_house on 2014-01-31 23:03:57
Hello. What is the best way to run the battery to amp wipe in the 850. I couldn't see a gromet in the bulk head to push the wire thru.
depending on the size wire. If its only a smaller gauge then theirs spare ports thru the bulkhead on the grommet the throttle cable goes thru, or if its a thicker wire then theirs a blank under the ABS pump on the passenger side
Thanks for that mr p :)
