V70 Indicator in mirror Guide
Post 687105 by Thanatos on 2014-02-04 21:03:30
I ordered a set of these to modernise the front of the v70 they fit v40 s70 960 850 v70 p1 http://www.polar-parts.de/body_parts/mirror_assembly/mirror_cover/mirror_caps_with_indicator_white_i60_982_0.htm I got mine from Ebay And they cost more but found the same ones cheaper after mine came I think once painted they will defo be a unique look on the v70 I did try making these two years ago and failed Image Image Image Image Image here they are ready for primer lens's removed Image Image Image and now with 2 coats of primer ready for top coat Image Image and the first of many topcoats Image Image well today they got 5 layers of topcoat and 6 layers of laquer and i have refitted the leds Image Image and a test fit on the car Image well iwas going to splice the left hand indicator into 24/2e-15 and24/2e-14 for the right this is the white 19pin plug on the firewall above the drivers pedals which might be a bit easier then my first thoughts after looking at the wiring diagrams
Post 687108 by JamesT5 on 2014-02-04 21:10:33
Nice shoes. :D
Post 687109 by jdavis on 2014-02-04 21:12:52
I quite like them.
Post 687111 by Thanatos on 2014-02-04 21:16:38
yeah my shoes end up in most pics being size 13 the mirrors really spruce the front end of the car up
Post 687113 by JUDGENINJA on 2014-02-04 21:25:56
Nice modern take..
Post 687119 by abdul on 2014-02-04 22:58:58
Have u got a ebay link to them
Post 687120 by Thanatos on 2014-02-04 23:03:35
Not now Abdul as it expired last night but they came from Germany in any case and were £30 dearer
Post 687121 by abdul on 2014-02-04 23:21:45
They are out of stock will order when available
Post 687122 by abdul on 2014-02-04 23:22:17
Where in the uk are u
Post 687126 by Thanatos on 2014-02-04 23:31:07
Blackpool Abdul They have the chrome ones on ebay Abdul A bit of bling for the laser ones http://www.ebay.co.uk/itm/Spiegelkappen-chrom-Volvo-850-S40-V40-S70-V70-/291057379425?pt=DE_Autoteile&hash=item43c45f2861
Post 687127 by Thanatos on 2014-02-04 23:35:05
And the white paintable ones http://www.ebay.co.uk/itm/360787338734?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Post 687128 by abdul on 2014-02-04 23:41:09
[QUOTE=Thanatos;687126]Blackpool Abdul They have the chrome ones on ebay Abdul A bit of bling for the laser ones http://www.ebay.co.uk/itm/Spiegelkappen-chrom-Volvo-850-S40-V40-S70-V70-/291057379425?pt=DE_Autoteile&hash=item43c45f2861[/QUOTE] A bit too much bling
Post 687129 by abdul on 2014-02-04 23:42:35
They definitely give the car a modern look
Post 687135 by V70 Graham on 2014-02-05 05:24:56
Nice, not seen these before.
Post 689666 by Thanatos on 2014-02-15 19:37:41
well just to update this they don't fit RHD cars Image Image Image this is the gap when trying to fit the drivers mirror
Post 689675 by abdul on 2014-02-15 20:04:30
Disappointed that they dont fit
Post 689677 by Thanatos on 2014-02-15 20:21:27
i was gutted i now looking for a lhd breaker to see if i can get them to fit
Post 689685 by V70 Graham on 2014-02-15 20:43:58
Shame, looked a nice little mod.
Post 689912 by partsforvolvos.com on 2014-02-17 11:29:15
sorry to see that you have found the answer to the question I was just about to ask ...... they only fit LHD. I have some of these in stock if anybody is interested and found the same thing. the angle of the mirror body is different. I asked the supplier if it might have been a moulding fault , but this was the reason I traced it to. you could modify the existing housing, and put in the led repeaters if you cut it very carefully?
Post 689937 by Thanatos on 2014-02-17 17:19:13
modding the RHD ones to fit is going to be a last resort as these are slightly moulded where the led's are and the screw holds the leds in to the housing isn't available on the Normal Housings either getting hold of a set of LHd Mirrors To Pack a side of the Motor mount out to make the Mirror angle useable on a rhd car
Post 694689 by Thanatos on 2014-03-12 18:34:25
just a quick update on this the left hand mirrors have arrived so after a quick paint well i managed to fit the drivers side to the car now its painted Image passenger side as normal view from the lhd mirror with rhd glass Image external 1 Image the workable mirror angle Image close up Image wider angle of the mirror Image i am going to be wiring these up on saturday as i need to reconnect the headlight indicators as well
Post 694799 by Thanatos on 2014-03-13 18:19:05
well i have now fitted the passenger side mirror Image Image Image
Post 695204 by Thanatos on 2014-03-15 19:38:57
and now the finished look Image and a short video [video=youtube_share;yRhBfe0Xhwo]http://youtu.be/yRhBfe0Xhwo[/video]
