Post 688327 by shepbomb on 2014-02-09 14:08:14
Looking for some help with this problem, ive tried everything, even with the switch removed the lights are permanently on, any solutions to this problem would be greatly appreciated
Im sure there designed to be like that dude
Later v40's are on, full stop. My 04 plate was like that but my 52 plate can be turned on and off as read. Nowt wrong so it, stop mithering Ste :-)
Just take the bulbs out then simples :)
850 has a little screw on the switch V70 - can't do anything
It doesnt bother me that they are permanently on, but you cant just switch to sidelights only. But if they are supposed to be like that...
You need to electronically disable them.
[QUOTE=munster732;688345]Later v40's are on, full stop. My 04 plate was like that but my 52 plate can be turned on and off as read. Nowt wrong so it, stop mithering Ste :-)[/QUOTE] you can disable any model 2000 on with a download via vida. did it on my dad's V40 04 plate from new because it has xenons, and they only just went last year .
If its your S40 then try this Ignition at pos 0 Turn light switch to 'sidelights' Ignition to pos II Pull on full beam and hold Turn light switch to '0' Release full beam Ignition off
