1999 v70 t5
Post 690852 by therat622 on 2014-02-22 08:26:40
hi, I have a v70 t5 1999 se, and the abslight is on, abs tries to kick in at low speeds then the light comes on and stays on? if anyone can help??? cheers!!!! Also as im new id like to know about the meets/shows aswell? I live in north Norfolk thank you!!! stuart
Post 691960 by therat622 on 2014-02-26 22:37:05
Prob sorted, plug on bottom of abs pump had crap init ;)
Post 691961 by merc85 on 2014-02-26 22:43:07
Glad you got it sorted, there is a Essex meet 9 March, see the organized meets thread mybe quite a drive for you tho :)
Post 692063 by FishingTed on 2014-02-27 19:47:48
Hi therat622, i have had T5's for a dozen years or more. Had similar problem with 2 of them. Check ABS sensors are clean on the wheels. But i have sent two ABS units to a guy called Victor Rocha in California and had them repaired /upgraded for what I thought was reasonable money. Just follow what he says on his website. About £120 if I remember correctly. If you remove the ABS unit with the correct t o r x socket it is easy. He shows how on website. Car will run and brakes work without the ABS unit. I found it much better in snow for stopping that way but thats aside. Insurance & risks running without unit would be all yours of course! 2 to 3 weeks timescale. But no problems when units upgraded and fitted. Kind regards FishingTed
