replacement actuator
Post 691653 by soothingduck on 2014-02-25 14:08:29
I'm changing the flange on my 16t to an angled flange. my old actuator is slack to going to replace it Am I correct in thinking I now need a actuator with a bent rod? and should I buy volvo or a aftermarket one?
Post 691657 by p fandango on 2014-02-25 14:30:13
I've always used a straight rod
Post 691659 by V70 Graham on 2014-02-25 14:50:00
I replaced mine last week and needed one with a bent rod.
Post 691660 by soothingduck on 2014-02-25 14:53:33
[QUOTE=V70 Graham;691659]I replaced mine last week and needed one with a bent rod.[/QUOTE] Any thoughts on the make?
Post 691661 by M-R-P on 2014-02-25 14:55:16
I struggle to see why it needs a bent rod tbh, it's not close enough to the compressor housing to foul it at all.
Post 691663 by V70 Graham on 2014-02-25 15:10:28
[QUOTE=soothingduck;691660]Any thoughts on the make?[/QUOTE] [QUOTE=M-R-P;691661]I struggle to see why it needs a bent rod tbh, it's not close enough to the compressor housing to foul it at all.[/QUOTE] I got a Forge one from Jamie at PFV, seems ok so far (can't give it a proper test till I sort my air intake out) The bent rod must be the 'hard to fit' model.....certainly took M-R-P a while :hilarious
