15g/16t turbo
Post 692364 by nottsgreent5 on 2014-03-01 20:48:31
Evening all as my 16t nearing the end can anybody tell me for sure if my 16t impelar and housing will fit onto a 15g core as i have 2 15s in very good shape doing nothing
Post 692386 by p fandango on 2014-03-01 23:36:53
[QUOTE=nottsgreent5;692364]Evening all as my 16t nearing the end can anybody tell me for sure if my 16t impelar and housing will fit onto a 15g core as i have 2 15s in very good shape doing nothing[/QUOTE] yes but the G has a different internal washer to the T so you'll have to rebuild it using a fastback rebuild kit
Post 692411 by nottsgreent5 on 2014-03-02 08:34:52
[QUOTE=p fandango;692386]yes but the G has a different internal washer to the T so you'll have to rebuild it using a fastback rebuild kit[/QUOTE] Thaanks for had a feeling there was a catch to swaping them lol
Post 692577 by Dangerous Dave on 2014-03-02 20:11:55
Plus it would need balancing....
Post 692702 by richcoad89 on 2014-03-03 14:04:47
[QUOTE=Dangerous Dave;692577]Plus it would need balancing....[/QUOTE] Best practice is to balance your turbo, mainly as it spins at 100,000,rpm.... however lots of people successfully run rebuilt turbos which have not been balanced. Depends whether you fancy taking the risk.
Post 692714 by 960kg on 2014-03-03 16:22:55
If you are buying a complete new core the whole thing is balanced as one upon rebuilding. If buying separate parts for the turbo they are all individually balanced!! The hotside impeller is already balanced on it`s shaft so when you fit the cold side balanced impeller it is still balanced as a whole. This is the reason some get away with it!......they are doing nothing wrong. A Quote from a supply company: "All our turbo parts are tested in our own builds and are run to destruction, we will not allow our companies name to be tarnished from poor quality turbo parts. We only source parts that meet iso standards at a minimum, and all parts are balanced individually and again as a rotating assembly (if purchasing complete units)"
Post 692718 by Dangerous Dave on 2014-03-03 17:21:00
Fair enough and TBH I did rebuild two turbos for my 850 which have had no problems and didn't go back together in exactly the same position.
