one of Europe’s premier performance remapping companies
Post 693001 by soothingduck on 2014-03-04 15:27:04
Just a thought but are all uk mappers "one of Europe’s premier performance remapping companies" or is it just me. FOR GOD SAKE who do you trust?
Post 693002 by p fandango on 2014-03-04 15:29:03
[QUOTE=soothingduck;693001]who do you trust?[/QUOTE] the simple answer to that is no one
Post 693015 by soothingduck on 2014-03-04 16:29:25
I've just found these people not far from me,so I think I'll do a drive by :) http://www.evolutionchips.co.uk/ Anyone used them? it's a national franchise
Post 693024 by M-R-P on 2014-03-04 17:12:37
which people?
Post 693049 by T5frankie on 2014-03-04 18:36:25
what car do you want to map?
Post 693064 by soothingduck on 2014-03-04 19:05:39
1997 v70 t5 2.3 auto with a angled flange 16t 3" turbo back exhaust down to 2.5" white injectors s60r exhaust manifold and a bit of porting to the head forge actuator forge recirc valve maybe forged rods
Post 693066 by T5frankie on 2014-03-04 19:07:06
[QUOTE=soothingduck;693064]1997 v70 t5 2.3 auto with a angled flange 16t 3" turbo back exhaust down to 2.5" white injectors s60r exhaust manifold and a bit of porting to the head forge actuator forge recirc valve maybe forged rods[/QUOTE] hlm then mate
Post 693068 by soothingduck on 2014-03-04 19:12:10
in Bromsgrove ? Is he call hamish?
Post 693074 by T5frankie on 2014-03-04 19:23:07
[QUOTE=soothingduck;693068]in Bromsgrove ? Is he call hamish?[/QUOTE] yes mate, he has all sorts of maps on file
Post 693080 by soothingduck on 2014-03-04 19:32:36
It's along way from graeme's which is where the exhaust will be fitted and on a standard map. But I was thinking of over-nighting somewhere nice between the two. maybe it would be best to fit the actuator and recirc at hlm? then remap (disconnect battery while fitting said parts) What do you think
Post 693085 by claymore on 2014-03-04 19:43:33
why fit the actuator at hlm, just don't thrash the car till it's mapped
Post 693087 by T5frankie on 2014-03-04 19:45:06
you aint gonna find someone to custom map your car mate, but a hlm map will be fine with your mods
Post 693088 by soothingduck on 2014-03-04 19:47:18
[QUOTE=claymore;693085]why fit the actuator at hlm, just don't thrash the car till it's mapped[/QUOTE] If you say it's ok then its ok and I will do just that. Should I fit the recirc aswell and a stronger spring? Thanks for the input
Post 693090 by soothingduck on 2014-03-04 19:49:33
[QUOTE=T5frankie;693087]you aint gonna find someone to custom map your car mate, but a hlm map will be fine with your mods[/QUOTE] I just what it to work frankie I also look forward to the 140 mile drive home
