Poxy Abs
Post 695671 by c70geoff on 2014-03-17 10:01:29
Right then folks Have changed everything even abs ecu with all matching numbers to now find it needs to be coded to my flipping car Can this be done without killing it who can do this bar a main stealer Help please
Post 695673 by M-R-P on 2014-03-17 10:07:54
Ello big fella :) I believe Hamish has the means to flash these things. Worth giving him a call.
Post 695678 by jamesy12345 on 2014-03-17 10:34:19
I changed my ABS ECU and it didn't need to be flashed?? I used these guys below.... https://www.midwest-abs.com/ (yeah I know in the US but there you go)
Post 695684 by Wobbly Dave on 2014-03-17 11:05:56
In the time I have been repairing ABS ECUs over the last 7 years - I have not heard of the requirement to code the ABS ECU to your car, not for the C70 Coupe for your model year at least. The repair either works or it doesn't (resoldering the pins). Usually the fault will clear itself or you can clear via ODB2.
Post 695922 by c70geoff on 2014-03-17 23:47:26
Have tried clearing using my snapon kit and comes back on after a few minutes Changed rings, sensors the lot Seriously loosing it with car now
Post 695927 by Wobbly Dave on 2014-03-18 00:14:39
What codes is it sending. If it is more than 1 corner then it is more likely a fault with the ECU & I would look to swap again just to be sure.
Post 695928 by c70geoff on 2014-03-18 00:22:24
No communication with sensor if I remember rightly You may end up having to send me your details Dave and I'll send my ecus to you please
Post 695953 by JT on 2014-03-18 07:14:36
have you read this?: http://www.vpcuk.org/forums/showthread.php?54628-ABS-TRACS-and-Speedo-working-intermittently Harveys link is useful:) http://www.ipdusa.com/techtips/10035/abs-tracs-codes
Post 695982 by c70geoff on 2014-03-18 10:47:46
Third ecu here so will try that first and have ordered full set of sensors too
Post 698408 by c70geoff on 2014-03-26 23:34:00
Abs issue sorted Left front sensor fecked even though was new in sept just gone so Volvo own part in place and all good for now
Post 698410 by Wobbly Dave on 2014-03-26 23:38:03
sadly it is the nature of the beast that it will be the last thing you try will be the fix. Good that you have it fixed finally.
Post 698412 by c70geoff on 2014-03-26 23:55:30
True that Dave Only reason I didn't check said item was that they where changed recent But that's what u get buying cheap copy parts And thanks as I'm glad to have her back too
