con-rods
Post 696238 by soothingduck on 2014-03-19 13:04:47
I've been looking for some con-rods and have found these: http://www.ebay.co.uk/itm/400485205689?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648 all looks fine except the big end dia is 53mm and the book of lie's say it should be 50mm can this be got round or do I need to keep looking?
Post 696258 by soothingduck on 2014-03-19 14:43:20
Is the 3mm the thickness of the shell
Post 696259 by partsforvolvos.com on 2014-03-19 14:44:52
it says 53mm in my pocket databook for a b5234t for the rods. the big end bearings are 50mm, so I guess that means the bearings are 3mm thick. anybody else confirm ?
Post 696260 by rikcougar on 2014-03-19 14:46:24
They should be a standard bore for the big end bearing, no reason to make them oversize Wobbly Dave is probably the man with the answer
Post 696270 by Jamest5r on 2014-03-19 15:19:19
Save any risk just get a set from Don/kalmar union many are/have used them about 360 quid the set
Post 696271 by soothingduck on 2014-03-19 15:25:11
[QUOTE=Jamest5r;696270]Save any risk just get a set from Don/kalmar union many are/have used them about 360 quid the set[/QUOTE] Thats £100 more
Post 696272 by soothingduck on 2014-03-19 15:28:17
[QUOTE=soothingduck;696271]Thats £100 more[/QUOTE] just looked and they are £396.50 on Ebay £260.00
Post 696273 by soothingduck on 2014-03-19 15:29:20
[QUOTE=partsforvolvos.com;696259]it says 53mm in my pocket databook for a b5234t for the rods. the big end bearings are 50mm, so I guess that means the bearings are 3mm thick. anybody else confirm ?[/QUOTE] This is how I understand it
Post 696279 by 960kg on 2014-03-19 16:10:13
Regrinds are classed as Undersize and cannot be Oversize!
Post 696280 by soothingduck on 2014-03-19 16:13:09
[QUOTE=960kg;696279]Regrinds are classed as Undersize and cannot be Oversize![/QUOTE] So the con-rod big-end dia is 53mm and so the Ebay rods are correct
Post 696353 by soothingduck on 2014-03-19 19:49:20
Ordered Thanks gents
Post 696405 by rikcougar on 2014-03-19 22:06:50
[QUOTE=960kg;696279]Regrinds are classed as Undersize and cannot be Oversize![/QUOTE] I thought we were discussing the big end bore in the conrod not the crankpin?
Post 696413 by Wobbly Dave on 2014-03-19 22:35:46
I spent 100 quid per rod for K1 tech rods. They are US made. I've spent money on where I believe it really counts because once the rods are in there, there is little you can do about it.
Post 696445 by soothingduck on 2014-03-20 01:30:04
The car will only be abit better than stock when finished,so I think they should be ok.
Post 696464 by don kalmar union on 2014-03-20 08:03:40
[QUOTE=Jamest5r;696270]Save any risk just get a set from Don/kalmar union many are/have used them about 360 quid the set[/QUOTE]# James, thank you for that! You can find them and order here on my website: http://kalmar-union.com/parts/volvo-850_s70_v70_c70-engine/ The price includes VAT and UK mainland delivery by TNT. The supplier quoted earlier is in Hong Kong so you would have to pay freight to the UK and, depending on just how it is delivered to you there should be VAT to pay. Regards, Don.
Post 696470 by Redbrick on 2014-03-20 08:29:03
[QUOTE=don kalmar union;696464] The supplier quoted earlier is in Hong Kong so you would have to pay freight to the UK and, depending on just how it is delivered to you there should be VAT to pay. Regards, Don.[/QUOTE] Free delivery but the VAT and import duty is going to be a wallop.
Post 696511 by soothingduck on 2014-03-20 11:37:59
I know I will need to pay vat but it will not be £135
Post 696513 by don kalmar union on 2014-03-20 11:42:37
I stand corrected Andy on the free delivery from HK. The VAT payable will be about £60 and there should be no other duties although there may be extra UK handling charges and other hidden extras payable prior to delivery. My sets also contain ARP bolts and I naturally buy them from a fellow in China whose brother has a take away at the bottom of my street........ Don.
Post 696514 by soothingduck on 2014-03-20 11:44:56
[QUOTE=don kalmar union;696513]I stand corrected Andy on the free delivery from HK. The VAT payable will be about £60 and there should be no other duties although there may be extra UK handling charges and other hidden extras payable prior to delivery. My sets also contain ARP bolts and are I naturally buy them from a fellow in China whose brother has a take away at the bottom of my street........ Don.[/QUOTE] Oh dear
Post 697881 by soothingduck on 2014-03-25 12:29:03
Con-rods £260 on Ebay plus £11 import duty. That's £130 cheaper than your's
Post 697883 by Jamest5r on 2014-03-25 12:45:37
[QUOTE=soothingduck;697881]Con-rods £260 on Ebay plus £11 import duty. That's £130 cheaper than your's[/QUOTE] Don't forget to add the bolts in :)
Post 697884 by soothingduck on 2014-03-25 12:48:39
They come with ARP 2000 bolts and lube
Post 697888 by T5RatherAmusin on 2014-03-25 13:16:05
ive never had import fees from HK/china etc....only usa- the swines!
Post 697889 by soothingduck on 2014-03-25 13:17:47
[QUOTE=T5RatherAmusin;697888]ive never had import fees from HK/china etc....only usa- the swines![/QUOTE] Yeah same here but at £11 I'm not moaning.
Post 697891 by T5RatherAmusin on 2014-03-25 13:19:19
:) also see the 2.5 ones are a little cheaper :)
Post 697892 by soothingduck on 2014-03-25 13:20:59
[QUOTE=T5RatherAmusin;697891]:) also see the 2.5 ones are a little cheaper :)[/QUOTE] You just can't knock it Chine is slowing down a bit so they are keen.
Post 697895 by soothingduck on 2014-03-25 13:24:20
Half the stuff we buy from uk seller's comes from china anyway. I was in retail so I know how it works. The list price was £285 but took £260 offer,
Post 697896 by p fandango on 2014-03-25 13:33:16
[QUOTE=T5RatherAmusin;697891]:) also see the 2.5 ones are a little cheaper :)[/QUOTE] S60R 2.5's are 143mm long, pre-ME7 2.3's are 139mm, & ME7 2.3's are 147mm
Post 697897 by soothingduck on 2014-03-25 13:35:20
2.3 with 147mm rod = loads of torque
Post 697899 by T5RatherAmusin on 2014-03-25 13:53:39
[QUOTE=soothingduck;697897]2.3 with 147mm rod = loads of torque[/QUOTE] im under the impression 2.4 t5 share the R rods bt if your saying the 2.3 are longer they obv dont share the same bore.... (2.3 and 4)
Post 697900 by soothingduck on 2014-03-25 14:03:09
[QUOTE=p fandango;697896]S60R 2.5's are 143mm long, pre-ME7 2.3's are 139mm, & ME7 2.3's are 147mm[/QUOTE] I was just quoting this and saying the longer rod would give it more torque.
Post 697901 by T5RatherAmusin on 2014-03-25 14:06:29
ye i kinda dint mean to quote yours tbh lol ;)
Post 697902 by graemewelch on 2014-03-25 14:09:59
[QUOTE=p fandango;697896]S60R 2.5's are 143mm long, pre-ME7 2.3's are 139mm, & ME7 2.3's are 147mm[/QUOTE] so do the s60r ones fit the 2.4 t5.
Post 697903 by graemewelch on 2014-03-25 14:11:14
[QUOTE=T5RatherAmusin;697899]im under the impression 2.4 t5 share the R rods bt if your saying the 2.3 are longer they obv dont share the same bore.... (2.3 and 4)[/QUOTE] i thought the same but i was told 2.4 t5 rods arnt as strong as the 2.5 s60r
Post 697906 by soothingduck on 2014-03-25 14:18:19
I thought there was 2 sizes one 139mm for the 2.3's and one 143mm for the s60r 2.5's No idea about the 2.4's
Post 697907 by soothingduck on 2014-03-25 14:23:59
Anyway the point is that I have 5 nice shiny rods that should cope really well in a sub 300 hp engine and are whisking they're way by DHL rickshaw and should be here in the morning. If i'm not in I believe they will drop them off at my local takeaway.
Post 697908 by T5RatherAmusin on 2014-03-25 14:29:06
[QUOTE=soothingduck;697906]I thought there was 2 sizes one 139mm for the 2.3's and one 143mm for the s60r 2.5's No idea about the 2.4's[/QUOTE] ye i get this this. a 2.3 set and a 2.5 set then a 2.4 woulvd been 2.5 rods and 2.3 bore... are these for that engine that are supose to already have them done?
Post 697910 by p fandango on 2014-03-25 14:39:44
[QUOTE=soothingduck;697897]2.3 with 147mm rod = loads of torque[/QUOTE] you'll need the shorter ME7 pistons to go with it Image 850 left, ME7 (aftermarket) right
Post 697911 by p fandango on 2014-03-25 14:42:27
[QUOTE=graemewelch;697902]so do the s60r ones fit the 2.4 t5.[/QUOTE] if your using the 93mm stroke, & ME7 pistons then yes you'd want the S60R (143mm) rods bore x stroke 81mm x 90mm = 2318.9cc 81mm x 93mm = 2396.2cc 83mm x 90mm = 2434.8cc 83mm x 93mm = 2516.0cc
Post 697912 by soothingduck on 2014-03-25 14:43:01
My engine it a 2.3 and my rods are 139.5mm which are for bt52**t3 engines. I will reuse the volvo pistons. The 143mm are for the others
Post 697913 by p fandango on 2014-03-25 14:49:03
[QUOTE=soothingduck;697912]My engine it a 2.3 and my rods are 139.5mm which are for bt52**t3 engines. I will reuse the volvo pistons. The 143mm are for the others[/QUOTE] while you've got the engine apart, have you thought about changing the crank to a later one (post 2002). 2.8kg lighter
Post 697914 by soothingduck on 2014-03-25 14:51:57
[QUOTE=p fandango;697913]while you've got the engine apart, have you thought about changing the crank to a later one (post 2002). 2.8kg lighter[/QUOTE] urmm would this be a direct fit? and I wonder where I would find one :deal:
Post 697915 by soothingduck on 2014-03-25 14:58:26
[QUOTE=p fandango;697913]while you've got the engine apart, have you thought about changing the crank to a later one (post 2002). 2.8kg lighter[/QUOTE] Also what would be the gain?
Post 697916 by graemewelch on 2014-03-25 14:58:52
[QUOTE=p fandango;697911]if your using the 93mm stroke, & ME7 pistons then yes you'd want the S60R (143mm) rods bore x stroke 81mm x 90mm = 2318.9cc 81mm x 93mm = 2396.2cc 83mm x 90mm = 2434.8cc 83mm x 93mm = 2516.0cc[/QUOTE] im sure the 2.5 has a larger bore. thats why the are weaker than the 2.4t5
Post 697918 by p fandango on 2014-03-25 15:11:42
[QUOTE=graemewelch;697916]im sure the 2.5 has a larger bore. thats why the are weaker than the 2.4t5[/QUOTE] for the B5244T5 Volvo went with the 81mm x 93mm so the S60R has got a wider bore
Post 697919 by p fandango on 2014-03-25 15:13:18
[QUOTE=soothingduck;697915]Also what would be the gain?[/QUOTE] lighter rotating mass means quick rpm build-up
Post 697920 by p fandango on 2014-03-25 15:17:59
[QUOTE=soothingduck;697914]urmm would this be a direct fit? and I wonder where I would find one :deal:[/QUOTE] might need to check the tolerances on the main bearing but that'll be all. I got mine off ebay for £125, thats a 93mm stroke tho
Post 697921 by soothingduck on 2014-03-25 15:22:08
[QUOTE=p fandango;697920]might need to check the tolerances on the main bearing but that'll be all. I got mine off ebay for £125, thats a 93mm stroke tho[/QUOTE] and I would need a 90mm stroke?
Post 697922 by p fandango on 2014-03-25 15:27:39
[QUOTE=soothingduck;697921]and I would need a 90mm stroke?[/QUOTE] yep, or you'd need shorter rods
Post 697926 by jamesy12345 on 2014-03-25 15:34:57
I came across this thread on the net http://volvospeed.com/vs_forum/topic/155507-aftermarket-rods-china-comparison/
Post 697950 by jamesy12345 on 2014-03-25 16:08:09
Something I've been wondering for a while.....can you change the rods & crank from below only, or do you need to take the head off as well as the sump....?
Post 697953 by graemewelch on 2014-03-25 16:12:46
[QUOTE=jamesy12345;697950]Something I've been wondering for a while.....can you change the rods & crank from below only, or do you need to take the head off as well as the sump....?[/QUOTE] head needs to come off.
Post 697954 by jamesy12345 on 2014-03-25 16:13:47
[quote=graemewelch;697953]head needs to come off.[/quote] doh
Post 697974 by graemewelch on 2014-03-25 17:32:35
[QUOTE=jamesy12345;697954]doh[/QUOTE] not a big job realy.
Post 697979 by theflyingbrick on 2014-03-25 17:57:24
ooooh my heads already off!!! hmmm I wonder if she would notice if a parcel came through the door?? anyone fancy taking delivery for me lol
Post 697985 by stribo on 2014-03-25 18:13:23
[QUOTE=theflyingbrick;697979]ooooh my heads already off!!! hmmm I wonder if she would notice if a parcel came through the door?? anyone fancy taking delivery for me lol[/QUOTE] Yeah, send them here mate, I promise they won't end up in my engine.;)
Post 697995 by soothingduck on 2014-03-25 18:22:52
No send them to me because I can make them look like a old Volvo set so she would never know.:saint:
Post 698074 by theflyingbrick on 2014-03-25 20:38:12
yeah no worries fellas as soon as I have your bank account details lol
Post 698240 by soothingduck on 2014-03-26 13:58:08
Well they are here and look great Fantastic service from seller so fast, 6 days delivery. Next on the list is volvo dealer
Post 698241 by T5RatherAmusin on 2014-03-26 14:00:26
that was quick! pics dude!
Post 698246 by soothingduck on 2014-03-26 14:37:20
Here you go [ATTACH=CONFIG]24262[/ATTACH] not sure if it works
Post 698309 by theflyingbrick on 2014-03-26 18:39:17
6 days?? I struggle to get stuff in the u.k delivered quicker lol looks like you've done well with this purchase,im gonna save the link for future reference ;)
Post 698326 by soothingduck on 2014-03-26 19:05:53
They look really good. Looks like the shell is cracked rather than cut. I've not had one apart yet but they do look that way. Got a list as long as my arm for Volvo. Think i'm going with Caffyns in Eastbourne seemed like a nice man and happy to do a deal also said he would put it in as a stock order and a bit of discount. Then the rest with PFV One thing I noticed on PFV was a boost gauge for £25ish yet a AEM boost gauge is £125. Is the AEM one better?
Post 698328 by T5RatherAmusin on 2014-03-26 19:12:08
sweet! same here dude! massive list! hella loada goodie with me next week :D get yourself a prosport evo gauge. very acurate and.... think it cost me boot 60 bob [ATTACH=CONFIG]24267[/ATTACH]
Post 698329 by soothingduck on 2014-03-26 19:15:31
I would prefer analog for both boost and AFR to be honest.
Post 698332 by T5RatherAmusin on 2014-03-26 19:17:25
for what reason? it has the bar graph that goes arond too.... if your cars quick it help to quick glance at it and not pretty much guess boost lol prosport do some good gauges tho bud ;)
Post 698342 by soothingduck on 2014-03-26 19:33:38
I like this http://www.ebay.co.uk/itm/121047498466?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648 Coz it's prity
Post 698343 by T5RatherAmusin on 2014-03-26 19:34:39
isit? :uglyhamme
Post 698345 by soothingduck on 2014-03-26 19:36:28
[QUOTE=T5RatherAmusin;698343]isit? :uglyhamme[/QUOTE] Think i'm a bit older than you mate(room for a old guy smiley here)
Post 698347 by T5RatherAmusin on 2014-03-26 19:38:17
hahahaa im one of the young ones here, yes. just turned 25 :pimp2:
Post 698348 by soothingduck on 2014-03-26 19:39:54
[QUOTE=T5RatherAmusin;698347]hahahaa im one of the young ones here, yes. just turned 25 :pimp2:[/QUOTE] just turned 50 :pimp2:
Post 698350 by soothingduck on 2014-03-26 19:42:57
this is my other ride [video=youtube;SlxIdBXIzqc]http://www.youtube.com/watch?v=SlxIdBXIzqc[/video]
