Post 700434 by Shevek on 2014-04-03 17:44:09
Hi All,
I have a C70 '04 plate with the Premium Dynaudio 13 speaker ProLogic, SC901, 4x100 amp setup
I have unfortunately blown the passenger door woofer.
How easy is it to source a Dynaudio replacement?
If not, what size is it for a replacement?
Any suggestions for similar quality brands?
TIA
Shevek
Post 700451 by stribo on 2014-04-03 19:25:19
I'd look for one that's being broken mate, coupe or convertible, GT spec, as the standard speakers are the nuts.
Post 700466 by rikcougar on 2014-04-03 19:55:20
If you are after pure sound quality Focal are the mutts
Be careful though, you will want to do them all and they ain`t cheap
Post 700489 by stribo on 2014-04-03 20:09:08
[QUOTE=rikcougar;700466]If you are after pure sound quality Focal are the mutts
Be careful though, you will want to do them all and they ain`t cheap[/QUOTE]
As you've had a C70 GT spec Rik, how do they compare to the dynaudios? are they that much better? I find the standard system set on pro logic is quality, and made me realise how bad the standard Cougar speakers were.
Post 700645 by Wobbly Dave on 2014-04-03 23:39:09
I have loads of these spare in my shed. Is it the big round 6 inch one?
Post 700665 by rikcougar on 2014-04-04 07:53:38
[QUOTE=stribo;700489]As you've had a C70 GT spec Rik, how do they compare to the dynaudios? are they that much better? I find the standard system set on pro logic is quality, and made me realise how bad the standard Cougar speakers were.[/QUOTE]
Focal are different league Steve, I have them hidden away in the Cossie (only four inch but they sound amazing) Dynaudio are good for oem but there is much better out there if you want to spend
Post 700760 by Shevek on 2014-04-04 15:06:09
[QUOTE=Wobbly Dave;700645]I have loads of these spare in my shed. Is it the big round 6 inch one?[/QUOTE]
I think that's the size... There are different ones though, the GT spec (like mine) have high end Dynaudo speakers...
Post 700925 by Wobbly Dave on 2014-04-04 22:10:30
Volvo C70s all had dynaudio AFAIK
Post 705808 by Shevek on 2014-04-23 16:17:18
Would you be willing to sell to me?
Post 709993 by Shevek on 2014-05-08 14:26:21
I've done some further research and it's the 8" speaker that I need - part no 3533793
Post 710377 by Wobbly Dave on 2014-05-09 22:48:24
[QUOTE=Shevek;709993]I've done some further research and it's the 8" speaker that I need - part no 3533793[/QUOTE]
I'll have a look. These are the ones from the bottom of the doors?
Post 710395 by volvokid on 2014-05-09 23:41:08
None of my volvos where close to as good sound quality as my C70 was.
Post 710490 by Shevek on 2014-05-10 12:53:00
[QUOTE=Wobbly Dave;710377]I'll have a look. These are the ones from the bottom of the doors?[/QUOTE]
Spot on, cheers!
Post 710491 by S70T5Chris on 2014-05-10 12:57:09
I had Focal's in the front of the S70. Running on a dedicated 2 channel Alpine amp. They set me back over £300. You have to spend quite a lot to get something better than the standard set up.
Post 711379 by Shevek on 2014-05-13 14:06:05
Would these be a good replacement?
http://www.focal.com/en/universal/377-iss-200-3544054750117.html
Post 711383 by Wobbly Dave on 2014-05-13 14:20:26
[QUOTE=Shevek;710490]Spot on, cheers![/QUOTE]
Sorry it slipped off the radar - I'll try to remember to have a look.
Post 711392 by M-R-P on 2014-05-13 15:40:01
I found running a quality sub and taking the low frequency sound away from the OE speakers a good way of adding clarity to the sound and giving the potential to turn it up a fair bit more. Good aftermarket headunit is also a must.
Post 711460 by Plodmonkey on 2014-05-13 19:59:06
Isn't the big 8inch ones at the rear of the car and not in the door
Post 711498 by Shevek on 2014-05-13 21:02:35
[QUOTE=Plodmonkey;711460]Isn't the big 8inch ones at the rear of the car and not in the door[/QUOTE]
This is what I have found from various places:
Convertible & Coupe:
Pair of 1 inch tweeters in the dash and either the Dolby centre speaker or Road Traffic pod in the centre
4 inch mid and 8 inch bass in each door
Convertible:
1 inch tweeter and 6.5 inch mid bass in each side panel
9 inch sub in each rear seat (option I think)
Coupe:
pair of 1 inch tweeters and 8 inch bass in the parcel shelf
This is from various posts and wiring and parts diagrams across the 'net
Post 711504 by stribo on 2014-05-13 21:11:15
I'm guessing this is the speaker you want:
Post 711526 by Shevek on 2014-05-13 21:53:50
[QUOTE=stribo;711504]I'm guessing this is the speaker you want:[/QUOTE]
Yep
Post 711531 by c70geoff on 2014-05-13 22:06:08
doors are deep enough for a tidy 8inch sub i reckon
Post 711551 by Shevek on 2014-05-13 23:05:03
[QUOTE=c70geoff;711531]doors are deep enough for a tidy 8inch sub i reckon[/QUOTE]
I was thinking that, but worried it would stop the windows from dropping all the way
Or even shatter them!
Plus I already have 2 x 9" subs in the back seats :D
Post 711554 by c70geoff on 2014-05-13 23:26:05
just been looking at some shallow fit 8inch jl audio subs and focal 4inch and tweeter set then id just have to get some 8inch jl audio super subs in the shelf hehe
