new suspension parts.
Post 700952 by ROZER on 2014-04-04 22:56:35
I got some parts for my s60 t5 I hate the handling of this car so I thought I should try to sort it out see if these help ,I got some powerflex rear bushes , meyle hd drop links front and back, and ball joints. has anyone done the rear wishbone bush yet how hard is it to get out and pop in .am working on the car in the morning on my back any tips would be good.
Post 700954 by M-R-P on 2014-04-04 23:03:09
You mean front wishbone rear bush?
Post 700955 by ROZER on 2014-04-04 23:08:46
yes dude
Post 700956 by ROZER on 2014-04-04 23:09:28
done the front one when you did yours.
Post 700958 by M-R-P on 2014-04-04 23:22:58
Cool... Hold on...
Post 700959 by M-R-P on 2014-04-04 23:25:20
clicky linky!
gotta take the wishbone off tho mate.
Post 700960 by ROZER on 2014-04-04 23:31:34
cheers mate that's the wishbone sorted have you ever done ball joints .
Post 700961 by M-R-P on 2014-04-04 23:34:44
[QUOTE=ROZER;700960]cheers mate that's the wishbone sorted have you ever done ball joints .[/QUOTE]
Yes, loads. You need to undo the 2 bolts that hold the ball joint to the stub axle and hammer screwdrivers between the stub axle and the ball joint plate, it takes a while and you need to go at it from both sides to get it out. Then you pop the splined end of the ball joint out of the wishbone when you do the rear bush.
Post 700963 by ROZER on 2014-04-04 23:43:57
thanks again.
Post 700964 by M-R-P on 2014-04-04 23:53:22
[QUOTE=ROZER;700963]thanks again.[/QUOTE]
You're welcome mate, I don't envy you lol.
Ball ache of a job lol.
Post 701228 by ROZER on 2014-04-05 21:11:03
done this today what a pig of a job my back is broke I could not get the rear bush back in so I had to undo the struts to get bottom ball joint in then I had to jack the wishbone up to put the 2 bolts in the subframe these powerflex bushes fight you all the way never again. took me all day in the rain but got the hd drop links done they where easy thank god.[ATTACH=CONFIG]24449[/ATTACH][ATTACH=CONFIG]24450[/ATTACH][ATTACH=CONFIG]24451[/ATTACH]
Post 701231 by ROZER on 2014-04-05 21:16:46
the old bush had a big tear in it .[ATTACH=CONFIG]24452[/ATTACH]
Post 701236 by T5RatherAmusin on 2014-04-05 21:25:29
nice one dude! they make a nice difference :)
Post 701239 by ROZER on 2014-04-05 21:31:17
[QUOTE=T5RatherAmusin;701236]nice one dude! they make a nice difference :)[/QUOTE]
cheers dude ,your right I have just took her out for a drive feels tight as am well happy
Post 701371 by JamesT5 on 2014-04-06 16:22:43
[QUOTE=ROZER;701231]the old bush had a big tear in it .[ATTACH=CONFIG]24452[/ATTACH][/QUOTE]
Nice work mate, I feel your pain with this because MRP and I did the same job on mine about 3 weeks ago - what a ball ache! It took Martin and I an absolute age to get mine done but we found the best way was leaving the lateral subframe to control arm bushings until last.
I commend you for going 100% powerflex on the wishbones mate, it's a mod I'd fully recommend and nice to see you've gone for a hard compound as well because I think it makes all the difference.
You'll feel the car had a slightly higher tendency to 'tram line' but your cornering will feel miles better. I've got to look at getting the rear end of mine done now but I'll have to find the bushings that fit both the S60 AWD and the V70 P2 FWD. PFV will supply and help with that I'm sure.
Good work! :B_thumb: :beer:
Post 701373 by JamesT5 on 2014-04-06 16:23:37
[QUOTE=ROZER;701239]cheers dude ,your right I have just took her out for a drive feels tight as am well happy[/QUOTE]
Feels like brand new when it's done doesn't it! :D
Post 701375 by JamesT5 on 2014-04-06 16:26:42
Oh, incidentally I also fitted the Meyle HD drop links so you and I have gone for the same approach with the suspension upgrade. :D :beer: :Handshake
Post 701381 by Harvey on 2014-04-06 17:03:42
[QUOTE=JamesT5;701371]I commend you for going 100% powerflex on the wishbones mate, it's a mod I'd fully recommend and nice to see you've gone for a hard compound as well because I think it makes all the difference.:[/QUOTE]
He hasn't gone for the hard range (black) he fitted the standard range (purple) ?.
Post 701386 by JamesT5 on 2014-04-06 17:26:12
[QUOTE=Harvey;701381]He hasn't gone for the hard range (black) he fitted the standard range (purple) ?.
[ATTACH=CONFIG]24451[/ATTACH][/QUOTE]
Yes, however the Black Range is only 25% harder than the purple range anyway. Purple is hard road use as you know, yellow is only about 10% stiffer than rubber iirc.
Post 701412 by ROZER on 2014-04-06 18:32:16
I went for the purple range because I have done the front lower wishbone in purple too. am planning on getting the pfv lowering kit next week not looking forward to that I have nimovats on the rear its an x police car.as for doing these wishbone bushes never again fell like an old man today back is killing me.
Post 701414 by JamesT5 on 2014-04-06 18:38:23
[QUOTE=ROZER;701412]I went for the purple range because I have done the front lower wishbone in purple too. am planning on getting the pfv lowering kit next week not looking forward to that I have nimovats on the rear its an x police car.as for doing these wishbone bushes never again fell like an old man today back is killing me.[/QUOTE]
I've got the PFV lowering kit on mine, it's fantastic value. The rear end will be the hardest mate, I watched two guys having fun getting the rear shocks in and that was at a garage on a ramp. If you can do your control arms I'm sure doing the shocks will be ok for you as well but take your time.
You may wish to consider changing from Nivomats to a standard strut arrangement, I know MRP has and it looks great. Martin is probably best qualified to advise you on that one. :)
Post 701418 by stephenevans99 on 2014-04-06 19:00:31
I've got a set of Lesjofors lowering springs that I've decided not to fit....originally bought from PFS and fitted to a D5 for a few weeks before the car was taken off the road.
http://www.partsforvolvosonline.com/product_info.php?cPath=2_160_1082&products_id=6691
Not advertised anywhere, but let me know if you're interested.
Post 701428 by JamesT5 on 2014-04-06 19:32:38
[QUOTE=stephenevans99;701418]I've got a set of Lesjofors lowering springs that I've decided not to fit....originally bought from PFS and fitted to a D5 for a few weeks before the car was taken off the road.
Not advertised anywhere, but let me know if you're interested.[/QUOTE]
Nice one Steve. :D
Post 701434 by ROZER on 2014-04-06 19:52:38
[QUOTE=JamesT5;701414]I've got the PFV lowering kit on mine, it's fantastic value. The rear end will be the hardest mate, I watched two guys having fun getting the rear shocks in and that was at a garage on a ramp. If you can do your control arms I'm sure doing the shocks will be ok for you as well but take your time.
You may wish to consider changing from Nivomats to a standard strut arrangement, I know MRP has and it looks great. Martin is probably best qualified to advise you on that one. :)[/QUOTE]
yes am Definitely taking the nimovats off the car and using the full kit I think its priced very good too.
Post 701437 by jdavis on 2014-04-06 19:58:02
Good work. Do they improve the ride well?
Post 701438 by ROZER on 2014-04-06 19:59:30
thanks mate but am only looking at fitting new cheers for the offer I appreciate it .
Post 701440 by ROZER on 2014-04-06 20:04:46
[QUOTE=jdavis;701437]Good work. Do they improve the ride well?[/QUOTE]
yes they do car feels tight I could tell when trying to put the wishbone arm back in with the new bush they would improve the steering the wishbone was miles away from the bottom ball joint no matter how much force I put on the wishbone I could not move them into place had to undo the struts and jack up to the subframe to get in its not a job for the weak you need to be strong or have someone help you .
Post 701443 by JamesT5 on 2014-04-06 20:13:56
[QUOTE=ROZER;701434]yes am Definitely taking the nimovats off the car and using the full kit I think its priced very good too.[/QUOTE]
The ride height is spot on and it feels nice too, a harder ride but then that's to be expected I suppose. The back camber will be noticeably negatively angled once the kit is fitted but I can say from experience that my tyre wear on the back hasn't really been affected to any appreciable degree. If you are concerned though, then PFV do a camber adjustment kit but I've left mine as it is for now as I think it gives safer cornering.
I'd strongly recommend you change your strut top bearings and spring seats as well unless you've just recently changed them. Mine were totally shot and to be honest, it's a little extra cash but will save you time in the future because there is a chance the harder ride could contribute to faster wear and tear on the older parts. It's entirely up to you of course but if you can spare the extra cash then go for the strut bearings and spring seats as well. PFV sell uprated spring seats that are about twice the price of the standard ones, I've not tried them but I guess they are better value in the long run.
Good luck with it all and let us know how you get on and what you think of it all when its fitted. :B_thumb:
Post 701445 by JamesT5 on 2014-04-06 20:18:06
[QUOTE=ROZER;701440]yes they do car feels tight I could tell when trying to put the wishbone arm back in with the new bush they would improve the steering the wishbone was miles away from the bottom ball joint no matter how much force I put on the wishbone I could not move them into place had to undo the struts and jack up to the subframe to get in its not a job for the weak you need to be strong or have someone help you .[/QUOTE]
Same problem that Martin and I had.
Post 701456 by ROZER on 2014-04-06 20:43:08
[QUOTE=JamesT5;701443]The ride height is spot on and it feels nice too, a harder ride but then that's to be expected I suppose. The back camber will be noticeably negatively angled once the kit is fitted but I can say from experience that my tyre wear on the back hasn't really been affected to any appreciable degree. If you are concerned though, then PFV do a camber adjustment kit but I've left mine as it is for now as I think it gives safer cornering.
Good luck with it all and let us know how you get on and what you think of it all when its fitted. :B_thumb:[/QUOTE]
cheers mate will look into the strut bearings and spring seats .
Post 701473 by JamesT5 on 2014-04-06 21:15:30
[QUOTE=ROZER;701456]cheers mate will look into the strut bearings and spring seats .[/QUOTE]
Nice one. Imagine if you take off your old shocks only to find your old ones are worn or past their best, at least you'll have peace of mind that a) you've got new parts to replace them but more importantly, b) you're putting new shocks and springs in to new strut bearings. I'm sure the reassurance will add to the driving pleasure when you drive down the road.
Post 701484 by ROZER on 2014-04-06 21:29:13
true .
