Post 701426 by s40t on 2014-04-06 19:25:03
Hi my names ashley im 21 and ive recently bought an 1998 s40 t4. :) a little about it:
its green!
[ATTACH=CONFIG]24460[/ATTACH][ATTACH=CONFIG]24461[/ATTACH][ATTACH=CONFIG]24462[/ATTACH]
108k
volvo stamps and mots
full leather interior
eleccy sunroof and windows all round incl heated mirrors
air con
bbs alloys
trip computer
6 cd changer
and you all probably no the rest lol
i swapped the car for my toyota starlet glanza repilca. just a n.a 1.3 with 159k! i thought i got the better end of the deal :D...
...then problems -.- it had an oil leak, the common cam seal, sorted this and a water leak from turbo hose, also fixed.
i NOW have developed a fault in boost. forgive me if ive repeated anything any other thread has covered, but its not boosting properly over 3k, its hesitating almost permanently. i know this is common but ive not read anywhere another part, im having a slight "beeping" noise as its happening. any ideas? apart from this, im very happy and impressed with the car! hope to speak to you all :)
Post 701439 by merc85 on 2014-04-06 19:59:57
welcome to the forum mate, looks a nice car, im sure someone on here will be able to help :)
Post 701458 by M-R-P on 2014-04-06 20:49:24
Hehe, starlet :)
sounds like ignition, a stage zero service would probably sort it... Plugs, leads, dizzy, coil, filters and fluids. Change all the vac hoses too.
welcome aboard.
Post 701488 by s40t on 2014-04-06 21:31:15
thanks guys :) i done a quick plug change and it doesnt seem as bad but its still just as bad if you get what i mean? more responsive when not hesitating, but still is. any ideas on a back box delete? i know its an airy subject
Post 701516 by JamesT5 on 2014-04-06 22:27:05
Welcome Ashely. Which neck of the woods are you in?
Post 701519 by M-R-P on 2014-04-06 22:38:09
[QUOTE=s40t;701488]thanks guys :) i done a quick plug change and it doesnt seem as bad but its still just as bad if you get what i mean? more responsive when not hesitating, but still is. any ideas on a back box delete? i know its an airy subject[/QUOTE]
Leads, dizzy and coil mate (unless it has coil packs) are gonna be worth doing.
Post 701520 by ks_p on 2014-04-06 22:41:26
[ATTACH=CONFIG]24482[/ATTACH]
Post 701559 by mitchyboy01 on 2014-04-07 10:36:09
Coilpacks fail on the T4's quite a lot. Take them out and carefully inspect the insulation on them. Welcome to the club!
Post 701579 by s40t on 2014-04-07 12:48:01
Thanks guys and I'm from Wiltshire in the south west. And I have coils, have insulated them but still doing going to get some more
Post 701665 by JUDGENINJA on 2014-04-07 21:00:50
If coil packs are failing, then change them both, but most people have said start with the basics and service it.
Most boost problems are vacuum pipes, but you'll need a methodical head to work through them to then move on to the actuator faults.
Post 701666 by Jim S70R on 2014-04-07 21:02:16
Nice car, welcome to the club!!
Post 703076 by jamesy12345 on 2014-04-13 19:30:03
Hello & :welcome:
Sorry, I'm a bit slow
