Post 702521 by Clippy on 2014-04-11 16:57:44
Hi
I own a C30, as I left work on Monday the car lost complete power, I managed to drive home with the assistance of the AA man who concluded that the car had an electonic faliure and he would be unable to find it due to the compexity, he also stated that it may not happen again yet could happen the next day.
Next day the car was fine, but yesterday I had an identical repeat, the AA man arrived again and got me home, this time he investigated a little further and found water droplets in the Central Electrical Module along with some scorching marks.
After cleaning and spraying the unit he said it would be improved but I should look into replacing it.
I ordered the part.
I got in the car today and suprise suprise.
This time I got the car straight to the garage, well I have just recieved a phone call telling me the car has been fixed total cost £920.40p,
Has anyone else had this fault / problem, I would also welcome any thoughts / comments
Regards
Clippy
Post 702523 by stephenevans99 on 2014-04-11 17:23:04
Just out of interest.... Where is the CEM located on a C30?
Post 702543 by Clippy on 2014-04-11 18:51:48
Passenger foot well, just under the glove box.
Post 702552 by Santa on 2014-04-11 19:20:34
I've not had a CEM unit replaced but replacement of Volvo control units is unfortunately expensive :(
Post 702559 by stephenevans99 on 2014-04-11 19:29:11
[QUOTE=Clippy;702543]Passenger foot well, just under the glove box.[/QUOTE]
It just made me curious as to where the water was coming from....could possibly a blocked drain on the scuttle panel, blocked/sodden pollen filter, heater matrix or even the AC drain from the evaporator. Would hate to think you replaced the unit for the same to happen again.
Post 702565 by Jamest5r on 2014-04-11 19:50:38
I bought my daily 850 fully modded for less than that ecu a year ago and all I've done is put petrol in it lol, can't stand modern electrics even me7 does my head in :)
Post 702567 by AAnickmac on 2014-04-11 19:56:36
this is a common problem on v50, s40 and c30. also ford focus. i went out to a v50 this morning with same fault. water gets into the fuse box and causes lots of issues. most of time you can remove and clean them, but it wont work properly till you have cleared the ecu of all the old codes. it might come up with abs systems fault, immobilser fault, airbag fault. when read it will say lost comunication with body control module. should clear once all connections are made good. and it should start. i have been out to lots and only not got one started.
Post 702599 by Clippy on 2014-04-11 20:49:57
I wasnt really that bothered about the price, it was the timing of the fault.....
Im in the Forces and im driving to Europe on Monday to start a new 3 year assignment, so needed to be confident the car would make the trip.
Post 702606 by M-R-P on 2014-04-11 21:07:15
Chavboy's old focus did the same thing, a swift kick to the fusebox sorted it.
I believe Volvo came up with a fix for this, I remember reading something about it on VOC.
Post 702620 by abdul on 2014-04-11 21:37:30
[QUOTE=Jamest5r;702565]I bought my daily 850 fully modded for less than that ecu a year ago and all I've done is put petrol in it lol, can't stand modern electrics even me7 does my head in :)[/QUOTE]
Totally agree
Post 702624 by ks_p on 2014-04-11 21:47:45
Absolutely dont understand anything in it!!! but i can just suport u, guys! ((:(:cry::cry:
