Well that was short lived !!!
Post 702887 by MoleT-5R on 2014-04-12 22:44:00
New box broken, in less than 30 miles, so no 1/4 tomorrow, it was looking so promising, went for a celebration pint and on the way home the crunching started and in neutral too, even brought the car to a standstill coasting in neutral, not good, will have to dissect it to find out whats failed,what a bummer :slap::slap:
Post 702888 by M-R-P on 2014-04-12 22:46:58
Awww mate, that sucks!
Post 702891 by MoleT-5R on 2014-04-12 22:52:14
Cheers Martin, initial testing was showing promise, but a gentle drive killed it .... lol..... back to the cave it will be
Post 702893 by WOODY T5 on 2014-04-12 22:53:46
gutted for u mate was hoping u would beat claymore frankie and jim`s times tomoz
Post 702894 by claymore on 2014-04-12 22:53:46
Post 702900 by V70 Graham on 2014-04-12 23:02:00
Sorry to hear of your setback Ade.
Post 702904 by MoleT-5R on 2014-04-12 23:14:36
[QUOTE=WOODY T5;702893]gutted for u mate was hoping u would beat claymore frankie and jim`s times tomoz[/QUOTE] it was looking interesting, but still plagued with a lack of boost [QUOTE=claymore;702894]££££££££ :([/QUOTE] better get flogging some bits off the 2.0litre to fund the next one [QUOTE=V70 Graham;702900]Sorry to hear of your setback Ade.[/QUOTE] first time I've broken one before an event, back to the cave then
Post 702923 by oblark on 2014-04-13 07:00:37
That's a bummer, :( You no what the answer is. ................ 6 speed conversion :)
Post 702936 by stribo on 2014-04-13 08:53:34
[QUOTE=oblark;702923]That's a bummer, :( You no what the answer is. ................ 6 speed conversion :)[/QUOTE] Ha ha, I was thinking the same thing ;) Sorry to hear of your setback Ade.
Post 702945 by T5frankie on 2014-04-13 09:19:26
[QUOTE=WOODY T5;702893]gutted for u mate was hoping u would beat claymore frankie and jim`s times tomoz[/QUOTE] maybe the other two's lol, bad luck adrian
Post 703012 by MoleT-5R on 2014-04-13 15:16:05
[QUOTE=oblark;702923]That's a bummer, :( You no what the answer is. ................ 6 speed conversion :)[/QUOTE] It was in mind, but I think the man that offered me one has now parted with it so will have to look for another, but in the meantime I'll rip the box apart and see what went wrong, it can only be a good thing to learn to re-build them and see what I can modify inside
Post 703014 by Jamest5r on 2014-04-13 15:20:03
You remember to put oil in it lol
Post 703060 by MoleT-5R on 2014-04-13 19:04:42
[QUOTE=Jamest5r;703014]You remember to put oil in it lol[/QUOTE] don't want to talk about oil, as it was all working fine in the donor (driven by us 120+ miles with no issues) I just popped it in as it was......don't think it's run out of oil, low on sawdust maybe......lol
Post 703173 by MoleT-5R on 2014-04-13 22:21:38
Here's a little vid we made earlier.... [video=youtube_share;8VvlIRo3NDg]http://youtu.be/8VvlIRo3NDg[/video]
Post 703175 by siamblue on 2014-04-13 22:39:04
Rebuilding gearboxes is quite a skill,when you see how many components there are inside.
Post 703178 by Volvostorm on 2014-04-13 22:40:58
I think the clutch friction plate has broke up.
Post 703185 by daza-b on 2014-04-13 22:52:13
[QUOTE=Pault5estate;703178]I think the clutch friction plate has broke up.[/QUOTE] Was thinking that too
Post 703189 by MoleT-5R on 2014-04-13 23:01:20
[QUOTE=siamblue;703175]Rebuilding gearboxes is quite a skill,when you see how many components there are inside.[/QUOTE] won't be the first gearbox I've stripped and rebuilt, but it will be my first Volvo box [QUOTE=Pault5estate;703178]I think the clutch friction plate has broke up.[/QUOTE] [QUOTE=daza-b;703185]Was thinking that too[/QUOTE] not ruling it out and hope your right as I don't really want to strip the box if I don't have to
Post 703193 by smithy on 2014-04-14 00:42:34
Sounds like the release bearing has collased to me
Post 703486 by MoleT-5R on 2014-04-14 23:40:07
we'll find out in the later part of the week when I get a chance to rip it again....oh the joy of doing it all again.....will be well practiced at this and earned me strips soon......lol
Post 704539 by adey on 2014-04-19 07:51:07
howdy have you pulled it a part yet ????
Post 704541 by MoleT-5R on 2014-04-19 07:57:49
[QUOTE=adey;704539]howdy have you pulled it a part yet ????[/QUOTE] not yet it will be mondays job I think mate
Post 704549 by cherry1809 on 2014-04-19 08:23:18
Keep us posted. If it's the clutch I sold you I'll gladly refund and apologize for wasted time :(
Post 704885 by MoleT-5R on 2014-04-20 13:12:36
[QUOTE=cherry1809;704549]Keep us posted. If it's the clutch I sold you I'll gladly refund and apologize for wasted time :([/QUOTE] That's very noble of you Sir, I don't think your part has failed clutch felt great to me, made need to build some bigger leg muscles though, just in case I get caught in a traffic jam.....lol
Post 704943 by MoleT-5R on 2014-04-20 15:58:23
Postmortem results in and I really need to give myself a swift kick up the arse, as I has become clear that numpty brains here drained the 10v box on removal and then put it to one side for a number of weeks and then didn't remember that I had drained it...!! When I fitted the box, I had decided as I could not find suitable oil for it locally I'd leave it to run on what was in it (the grey matter is not what it was lets say) running on nothing wasn't good and I had thought of just adding oil and seeing if I'd get away with it, but having looked in though the reversing switch hole and seen the mass of small metal fillings in there I'm having second thoughts. So gearbox out and strip down in the vain hope the crown wheel and pinion will be useable in my spare m56 I have here. So there we have it what a NUMPTY I am, can't believe I didn't remember draining it......:troutslap:nutkick:
Post 704947 by t5 pete on 2014-04-20 16:07:14
Its so easily done Adrian especially when your not on with it all the time I constantly have to check and double check things with the gul as its been months since some things have been removed
Post 704948 by stribo on 2014-04-20 16:12:58
Nightmare mate, that's a hard lesson learnt.
Post 704960 by MoleT-5R on 2014-04-20 16:43:29
Thanks guys sure it will take a while for me to live this down....lol Whilst we're on the gearbox subject, what box was fitted to p1 v70r's ph1&2 ???
Post 704963 by merc85 on 2014-04-20 16:46:27
ph1 v70r m59
Post 704965 by Jamest5r on 2014-04-20 16:49:56
[QUOTE=Jamest5r;703014]You remember to put oil in it lol[/QUOTE] Ermmmm....... hate to say I.told you so mate.....
Post 705083 by MoleT-5R on 2014-04-20 20:16:44
[QUOTE=Jamest5r;704965]Ermmmm....... hate to say I.told you so mate.....[/QUOTE] took your time , been waiting for your post....lol
Post 705098 by claymore on 2014-04-20 20:38:37
You sir are a ££££ing idiot.....lol
Post 705104 by smithy on 2014-04-20 20:50:19
What a spanner Adrian or should I say numpty lol.if you need another one I will see what I can do .
Post 705107 by p fandango on 2014-04-20 21:00:22
i've got the internals (except the diff) from a standard M56H if there any good to you, going to bin them soon if not
Post 705171 by MoleT-5R on 2014-04-21 00:54:22
[QUOTE=merc85;704963]ph1 v70r m59[/QUOTE] got a set of v70r driveshafts kicking about here and was wondering how to tell which box they fit, as I don't know whether there phase 1 or 2
Post 705172 by MoleT-5R on 2014-04-21 01:00:17
[QUOTE=claymore;705098]You sir are a ££££ing idiot.....lol[/QUOTE] And you Sir are 100% correct [QUOTE=smithy;705104]What a spanner Adrian or should I say numpty lol.if you need another one I will see what I can do .[/QUOTE] That I am mate, hoping to still be able to use the crown wheel and pinion in the spare m56 I have on the bench here [QUOTE=p fandango;705107]i've got the internals (except the diff) from a standard M56H if there any good to you, going to bin them soon if not[/QUOTE] Thanks, I'll give you a shout if I'm stuck for anything
Post 705173 by siamblue on 2014-04-21 03:27:31
[QUOTE=MoleT5-R;705171]got a set of v70r driveshafts kicking about here and was wondering how to tell which box they fit, as I don't know whether there phase 1 or 2[/QUOTE] What do you mean? all p2 classics were auto as well as p3..
Post 705209 by MoleT-5R on 2014-04-21 11:04:54
[QUOTE=siamblue;705173]What do you mean? all p2 classics were auto as well as p3..[/QUOTE] I know P1 Phase 3's we're all auto and AWD, but was unsure regarding phase2's , so only phase1 V70R's were FWD manuals then, as I'm trying to work out what the set of driveshafts are that I have here? They are from a FWD I'm sure of that but not sure if auto or manual ???
Post 705210 by siamblue on 2014-04-21 11:33:36
There was only a P1 R in both auto and manual mate 97 and 98 ...p2 99 and p3 00 were all auto.. But i think i know what youi are saying now lol..
Post 705211 by Nealevo on 2014-04-21 11:36:44
Unlucky mate, a million things going one you were sure to forget something, it was an import thing thou :) numpty
Post 705212 by siamblue on 2014-04-21 11:41:15
[QUOTE=Nealevo;705211]Unlucky mate, a million things going one you were sure to forget something, it was an import thing thou :) numpty[/QUOTE] We have all done it,i forgot to nip up the bolt at the back of the engine for the turbo feed once,luckily i left it running and i saw a big puddle of 10w40 on the floor..could of been so much worse..
Post 705216 by MoleT-5R on 2014-04-21 12:22:36
[QUOTE=Nealevo;705211]Unlucky mate, a million things going one you were sure to forget something, it was an import thing thou :) numpty[/QUOTE] seriously kicking myself, but it has pushed me to do a little final drive rebuild, that was on the cards for next year, just a little sooner than planned
Post 705230 by claymore on 2014-04-21 14:30:03
[QUOTE=Nealevo;705211]Unlucky mate, a million things going one you were sure to forget something, it was an import thing thou :) numpty[/QUOTE] Yep, I tend to forget bonnets :)
Post 705232 by cherry1809 on 2014-04-21 14:43:30
Arse! If I had mine in the unit I've been waiting on you could have had the gearbox from that :(
Post 705294 by MoleT-5R on 2014-04-21 18:57:03
[QUOTE=claymore;705230]Yep, I tend to forget bonnets :)[/QUOTE] yes, but I'm only ever going to forget gearbox oil once sir.....lol
Post 705340 by Jamest5r on 2014-04-21 20:03:43
[QUOTE=MoleT5-R;705294]yes, but I'm only ever going to forget gearbox oil once sir.....lol[/QUOTE] Touche :)
Post 705344 by stribo on 2014-04-21 20:07:42
[QUOTE=MoleT5-R;705294]yes, but I'm only ever going to forget gearbox oil once sir.....lol[/QUOTE] I'll wait until the next gearbox is fitted before I cast judgement. ;)
Post 705419 by MoleT-5R on 2014-04-21 22:33:05
[QUOTE=stribo;705344]I'll wait until the next gearbox is fitted before I cast judgement. ;)[/QUOTE] the old one will have to go back in for a while, then I fit the new improved one and may be you'll wish that I'd put oil in the first one......haha.......lol
Post 705422 by claymore on 2014-04-21 22:43:37
[QUOTE=MoleT5-R;705419]the old one will have to go back in for a while, then I fit the new improved one and may be you'll wish that I'd put oil in the first one......haha.......lol[/QUOTE] That's a bit cryptic, can I take it that Me buying a Jag means a silver lining for you ;)
Post 705426 by MoleT-5R on 2014-04-21 23:07:10
[QUOTE=claymore;705422]That's a bit cryptic, can I take it that Me buying a Jag means a silver lining for you ;)[/QUOTE] thought you were selling the S60 !!!, but I wouldn't want the Olive going out of our circle if you know what I mean
Post 705427 by claymore on 2014-04-21 23:08:13
[QUOTE=MoleT5-R;705426]thought you were selling the S60 !!!, but I wouldn't want the Olive going out of our circle if you know what I mean[/QUOTE] I was alluding to Scott ;), the Olive is going nowhere mate :)
Post 705428 by MoleT-5R on 2014-04-21 23:15:48
[QUOTE=claymore;705427]I was alluding to Scott ;), the Olive is going nowhere mate :)[/QUOTE] Thank god for that......Up to speed now, yer thanks will have to do a bit of scrabbling about but it will be worth it, as I think I can get everything together for York, so it will be an interesting weekend then !!
Post 705432 by MoleT-5R on 2014-04-21 23:39:15
[QUOTE=p fandango;705107]i've got the internals (except the diff) from a standard M56H if there any good to you, going to bin them soon if not[/QUOTE] Like to take you up on that offer, as had a chat with Carl this afternoon and a rebuild is on the cards, pm me and we'll sort the details, thanks again
Post 705438 by p fandango on 2014-04-22 00:11:37
[QUOTE=MoleT5-R;705432]Like to take you up on that offer, as had a chat with Carl this afternoon and a rebuild is on the cards, pm me and we'll sort the details, thanks again[/QUOTE] i'll get it all sorted out & in a box, i think its going to be too heavy to go thru the post so will have to see what can be done to get it too you
Post 705439 by MoleT-5R on 2014-04-22 00:17:38
[QUOTE=p fandango;705438]i'll get it all sorted out & in a box, i think its going to be too heavy to go thru the post so will have to see what can be done to get it too you[/QUOTE] Thanks Duane, I'm sure the VPC pony express can be swung into action on this one, no really hurry a couple of weeks will be fine, so plenty of time for us to work it out, The T-5R will back on the road with its old box this week and the V70R AWD will then be in for its manual conversion as soon as the garage is clear, busy times ahead....lol
Post 705440 by p fandango on 2014-04-22 00:22:04
no problem, it'll be nice to get them cleared out the wat. I'm not sure if any of the mob going to Donnington saturday will be able to forward it onto you somehow
Post 707456 by Dan850r on 2014-04-29 17:05:11
ive got two m56h boxes here if any good, in oswestry Shropshire.
