s40 t4 p1 injector upgrade
Post 704441 by weemo1rush on 2014-04-18 19:08:39
Hello chaps. OK I'm after a few pointers. I have a mild modified s40 t4 p1. Exhaust , Panel filter, actuator adjusted. I'm thinking of an adjustable fuel pressure regulator. And some new injectors I've been told that bosch reds work well for un upgrade from standard greys. Any of you guys done similar? Regards Davo
Post 705178 by s40t on 2014-04-21 03:54:35
[QUOTE=weemo1rush;704441]Hello chaps. OK I'm after a few pointers. I have a mild modified s40 t4 p1. Exhaust , Panel filter, actuator adjusted.[/QUOTE] is this the cheeky little mod ive heard of popping the small clip to turbo and winding out the nut? [QUOTE=weemo1rush;704441]I'm thinking of an adjustable fuel pressure regulator. And some new injectors I've been told that bosch reds work well for un upgrade from standard greys. Any of you guys done similar? Regards Davo[/QUOTE] im also intrested in this upgrade!? ive been told its a straight swap from another model? bosch greens though?
Post 705606 by artfulflounder on 2014-04-22 21:08:42
Standard injectors are good for 250 plus bhp which I doubt you'll be near yet. best bet is to contact someone like dom at kalmar union for a mte re map. make the most of what you've already got.
