C70. Just won't fire .......
Post 704640 by The Flying Banana on 2014-04-19 18:19:19
Been using the C70 as a daily, been going great came home Thursday night and parked up. Came out this morning and it turning over but refuses to fire.. Changed the antenna ring, found a snapped earth cable on engine so fixed that but no joy, seems immobiliser related as not getting spark ( changed out coil etc ) ....any ideas ? It's a 98 C70 T5 GT Could the ECU fail in some way ?
Post 704644 by stribo on 2014-04-19 18:29:46
Is it M4.4, or ME7, can you hear the fuel pump priming?
Post 704650 by claymore on 2014-04-19 18:39:53
try the crank sensor
Post 704656 by merc85 on 2014-04-19 18:57:04
As above, or the cam sensor ;)
Post 704657 by p fandango on 2014-04-19 18:58:14
Try reading the codes & see what it says
Post 704670 by The Flying Banana on 2014-04-19 19:25:30
Ignorance here....where is crank or cam sensor ....can't get it running to get it to a garage for codes tho maybe just need to get it recovered to get it to a garage Found the cam sensor..crank one to find now
Post 704671 by The Flying Banana on 2014-04-19 19:26:07
[QUOTE=stribo;704644]Is it M4.4, or ME7, can you hear the fuel pump priming?[/QUOTE] It's 4.4 and yes I here pump running
Post 704673 by p fandango on 2014-04-19 19:28:39
[QUOTE=The Flying Banana;704670]Ignorance here....where is crank or cam sensor ....can't get it running to get it to a garage for codes tho maybe just need to get it recovered to get it to a garage[/QUOTE] is there no one local who can read them for you, because you really are wasting your time (& money) just replacing random sensors when the whole idea of having diagnostics is too stop the guess work
Post 704674 by merc85 on 2014-04-19 19:29:46
The cam sensor is on the end of the Exhaust camshaft, The Crank Sensor is directly in the Top of the Bell Housing where the Box meets the Engine held in with One 10mm
Post 704715 by The Flying Banana on 2014-04-19 20:56:42
Cam sensor price...OMFG !
Post 704716 by merc85 on 2014-04-19 20:58:40
[QUOTE=The Flying Banana;704715]Cam sensor price...OMFG ![/QUOTE] is yours 1998 me7? or has it got a throttle cable (pre me7) if its looks like this i have a good used one you can try [ATTACH=CONFIG]24646[/ATTACH]
Post 704721 by The Flying Banana on 2014-04-19 21:10:54
It has a throttle cable , will try get a code reader as Pedro is right....could be wasting money and time
Post 704722 by merc85 on 2014-04-19 21:17:19
You have pm
Post 705678 by The Flying Banana on 2014-04-23 09:13:52
i took this off to have a look and get ready to put another in i cant believe that this small disc with what looks like some bits from Maplins can stop the car in its tracks lol
Post 705699 by mike 850 on 2014-04-23 10:20:28
put a volt meter across the cam sensor wires, if it oscillates between 0-5v while cranking it should be ok, can you feel the icv vibrating with ignition on?
Post 706532 by The Flying Banana on 2014-04-26 16:19:26
Sorted...big thanks to Merc85... It was the cam sensor after all so all good now :)
Post 706548 by Yosser on 2014-04-26 17:44:04
Sorry I missed this thread, glad you got sorted. For future reference, I have code readers to cover most Volvos and I'm not too far away.
Post 706688 by The Flying Banana on 2014-04-27 00:40:53
Thanks buddy I will keep that in mind :)
