Post 705400 by multiskilled on 2014-04-21 21:32:47
Hi all
thinking about tee ing off the pcv pipe from the top off the engine near the oil filler cap that runs down to the oil trap.
Was planing on joining on to the pipe under the inlet manifold then runing a sort of upside down u bend to stop any oil leaking out then run it down to vent into atmosfere near the sump.
I had my whole pcv replaced last year but think my valve guides may be worn causing more pressure than my pcv can cope with.
Done the glove test and theres pressure there and smoke from oil filler cap and a bit from dip stick
Post 705413 by merc85 on 2014-04-21 22:06:09
who replaced it? if you have excess crank case pressure there may well be a underlying cause. My valve stem seals were worn on mine but i didnt have any pcv smoke.
Post 705414 by p fandango on 2014-04-21 22:11:26
did they replace just the PCV unit or the pipes as well, pipes getting blocked with oil seems to cause more problems than the PCV itself
Post 705420 by multiskilled on 2014-04-21 22:36:08
They replaced the whole thing new catch tank and pipes apart from the expensive one which was cleaned out with air line
Post 705425 by stribo on 2014-04-21 23:00:25
Are you running standard boost pressure?
Post 705429 by multiskilled on 2014-04-21 23:17:31
As far as i no i havnt got a boost guage
