So the Rica map is my cough/splutter issue...............
Post 706544 by foammanmark on 2014-04-26 17:36:01
Whilst with Munster in Barnsley today, we tried both a standard R and a mapped ecu, both of which worked absolutely fine with my car. No sign at all of the cough/splutter that my car has been suffering with at 3,500rpm, so I can eliminate the plugs etc. Now to look at what I can do with my current ecu as I don't have a spare, or I'm buying one of Wayne(Munster), if one of his should become available. Thanks for helping me find the cause Wayne.
Post 706546 by T5frankie on 2014-04-26 17:40:20
same issue deathrider had with his mapped ecu, tried one of mine and all was good
Post 706549 by foammanmark on 2014-04-26 17:45:09
[QUOTE=T5frankie;706546]same issue deathrider had with his mapped ecu, tried one of mine and all was good[/QUOTE] It's just good to know what the issue is sometimes, cos you start thinking of all kinds of things. Had no plan to do this today as I just went over to give Wayne/Pete their mats, but when Wayne mentioned the standard ecu, the plan fell into place.
Post 706558 by Santa on 2014-04-26 18:53:50
It could be a direct cause of the map but it might also be a failing piece of hardware on the car. Maps tend to push hardware harder so it is possible that even if you ran standard for a bit the issue may occur.
Post 706561 by Rudeyboy18 on 2014-04-26 19:05:40
I have a HLM off the shelf ecu up for grabs. No issues , had it in for 2years.
Post 706562 by foammanmark on 2014-04-26 19:08:15
[QUOTE=Rudeyboy18;706561]I have a HLM off the shelf ecu up for grabs. No issues , had it in for 2years.[/QUOTE] Manual/FWD joi please?
