Tcm 002c fault
Post 707184 by Robbieb on 2014-04-28 17:02:50
Hi guys finally got all errors codes off my car been off for a week was going up motorway other day and boom urgent transmission service required message came up and car got stuck in gear i think it was 4th had a friend plug car into his snap on device and he said the code is tcm-002c i know what the code means, " TCM-002C 5th gear. Incorrect gear ratio" could some tell me if the tranny is dead or is this a fixable problem any help would be great oh its a v70 T5 on a 2001 plate. Gearbox seams to stay in that gear even when pulling away however once it's been turned off for a while will go through the gear all be it very ruff. many thanx
Post 707193 by Harvey on 2014-04-28 17:44:12
Does the car history's list gearbox oil change ever ?. Not very good news this fault what age is the car and what miles are on it,up to 2005 year cars their is a gearbox oil level dipstick might be worth a look to see what colour the transmission fluid is,also if it smells burnt. It should be red in colour but if it's jet black looks like it hasn't been changed so bad news.
Post 707201 by jdavis on 2014-04-28 18:13:05
I've just had this on mine but 2nd 3rd and 5th. New gearbox time. I have a sipping 1st 2nd and 3rd then drives ok in 4th
Post 707205 by Robbieb on 2014-04-28 18:29:46
It's done 160k no history oil level full but its a clear fluid
Post 707342 by jdavis on 2014-04-28 23:44:48
What as in water clear. Oil cooler in rad may have split causing water to get in. What's the expansion tank like?
Post 707371 by Robbieb on 2014-04-29 07:52:54
Yer as in water clear ill check the tank today
Post 707476 by Robbieb on 2014-04-29 19:21:21
Is there an easy way to check the oil cooler in the rad?
Post 707482 by Harvey on 2014-04-29 19:35:14
Just to doublecheck it is gearbox dipstick that you are looking at,oil level tested with the engine running ?. Image Very strange for the fluid to be clear ?.
Post 707597 by Robbieb on 2014-04-30 07:42:21
Yep that is where I check and yep its clear
Post 707618 by 960kg on 2014-04-30 13:31:45
This may help .....
Post 709357 by Robbieb on 2014-05-06 13:49:13
Ok well looks like gearbox is dead :-( I do have another box problem is the wiring is differant does any one know is there a way to change the wiring to get it to fit?
