Post 707464 by dannyboy101 on 2014-04-29 18:28:00
For those of you with an induction kit. Did you use a straight samco connector? Im struggling to find a mounting point for the bracket. The only way i can see it working is if i use the hole on the right wing where the airbox was mounted too. Did you also remove the plastic air feed from the grill which used to connect to the bottom of the airbox.
