Post 708809 by Harvey on 2014-05-04 17:55:14
Have the rims you have fitted have the correct offset ?,there is something very wrong,did the car come with the rims fitted ?,what is the handbook say about the tyre size you should have fitted.
Has someone removed the steering stops.
Post 708812 by merc85 on 2014-05-04 18:01:54
Go down to 40 profile mate, or even a 45 will better than nowt, Ive gotta be honest Ive had 5 volvo 850's and 1 ph1 v70 and ph2 v70 non of them have ever suffered with the tyres rubbing on the inner arch in my ownership.
Are tyre's run at the right tyre pressure? may be worth while checking the wheel alignment to,
Big rotch 850 did but that was because some numpty was running 205/55/16's, as soon as they were changed to to 205/50/16's it was all good.
Post 708814 by merc85 on 2014-05-04 18:03:23
Looking at those pic's harvey may well be right those wheels look like they sit abit far into the arch to me, and there not standard ph1 v70 rim's either
Post 708815 by c70geoff on 2014-05-04 18:04:41
Defo not right
Mine rub a little on full lock with 18s but never on the 17s
My way around it is getting some hubcentric spacers but as said above that looks wrong as tyre should never be that close
Post 708826 by Henk on 2014-05-04 18:50:08
i thought the 50 profiles would be big but they're not bad at all, plus living in mid wales and a mountain biker i kinda like having 50 over 40 profile for rough roads and stuff
they came off a standard volvo though, and probably about the same as an 18 with 40 profiles on.
starting to wonder if they might be rubbing on something else too, some serious cut considering that on the car side it's only rubbing, not a sharp surface
something to do with thicker diesel wishbones or anti roll bar, i dunno. musing out loud
I've got some pegasus' in crap condition that i might throw some paint on and try out instead, they're dead popular so offset/width on them can't be an issue
Spacers are out though due to no longer wheel bolts
Post 708890 by Henk on 2014-05-04 21:40:28
standard wheel bolts are 28mm though, advert is kinda a lie...?
Post 708904 by c70geoff on 2014-05-04 21:53:32
I have some spacers down the road from u if u wanted to pick them up and give them a try
Post 708921 by claymore on 2014-05-04 22:11:24
[QUOTE=Henk;708890]standard wheel bolts are 28mm though, advert is kinda a lie...?[/QUOTE]
That's weird, the link doesn't go to web page I put up?
EDIT: This is the page I put up, and they do up to 35mm thread:
http://www.performancealloys.com/wheel-nuts-wheel-bolts.aspx?
Post 709023 by 960kg on 2014-05-05 08:53:16
[QUOTE=claymore;708921]That's weird, the link doesn't go to web page I put up?
http://www.performancealloys.com/wheel-nuts-wheel-bolts.aspx?[/QUOTE]
I am glad the page went wrong Lol as they are just up the road from me in Kent.
In your opinion do you think the spacers etc. on that wrong Link will be ok or should i go to the other proper link as they may be better quality parts?
I won`t hold you responsible if the wheels drop off!....but just wondered what you thought yourself because of all the meddling you involve yourself in with Volvo`s ...
Post 709026 by claymore on 2014-05-05 09:04:10
The spacers on that link are fine, but the bolts they supply with them are mild steel with a cone washer, I almost lost a wheel with one of them on:
Post 709034 by 960kg on 2014-05-05 09:33:58
[QUOTE=merc85;708812]
Big rotch 850 did but that was because some numpty was running 205/55/16's, as soon as they were changed to to 205/50/16's it was all good.[/QUOTE]
Not arguing at all merc, but i find that strange as i have the same motor but is 40mm lower and also it has 205/55/16`s on Perfos and does not touch anywhere!!
One good thing with that ratio is the speed is exactly in line with GPS.... 30mph on the clock = 30mph GPS and the same through out....
As you say the OP has the wrong rims on with the wrong offset...
Post 709035 by merc85 on 2014-05-05 09:38:26
[QUOTE=960kg;709034]Not arguing at all merc, but i find that strange as i have the same motor but is 40mm lower and also it has 205/55/16`s on Perfos and does not touch anywhere!!
As you say the OP has the wrong rims on with the wrong offset...[/QUOTE]
yes strange, perhaps the suspension had sagged alittle over age. dunno, but it didnt rub after the change
Post 709205 by Henk on 2014-05-05 20:23:19
[QUOTE=claymore;709026]The spacers on that link are fine, but the bolts they supply with them are mild steel with a cone washer, I almost lost a wheel with one of them on:
[/QUOTE]
interesting just a caphead bolt with a tapered washer?
I've got some ford 5x108 adapters, but i think i'll look at getting the other wheels on, even though they're in crap condition still
Driving to Germany at the end of the month so need to get the car all sorted!
Post 709439 by Henk on 2014-05-06 20:32:43
should be getting a new pair of Maxxis MAZ3's on Friday, will get 205/50/R17
What do people generally run on Pegasus'?
